Author Topic: Not sure if I need to shim my rear end  (Read 1836 times)
AGUHR
« on: October 23, 2010, 06:33:33 PM »
I installed an SYE and replaced my skid plate bolts with short bolts to get rid of the spacers. I installed a 1 inch lift BrownDog motor mount also.
The difference between the top measurement (18 3/8) and the bottom measurement (18 1/2)  is 1/8 of a inch difference. Will a double cv drive shaft take care of that or do I need to install a 2 degree shim and still use a double cv shaft?
I've got a 2.5" sys lift and 1" BL on 33's.
thanks for the help.
Re: Not sure if I need to shim my rear end
« Reply #1 on: October 23, 2010, 07:30:08 PM »
your pinion/yoke axis should have the same angle as the driveshaft or a bit under (like a degree or 2) - take a pic from under the left rear fender.
redYJrider
« Reply #2 on: October 25, 2010, 02:08:14 PM »
I tried running mine w/o shims but the drive shaft angle was too sharp and I got some bad vibrations. I'm up on a 4" lift though.
« Reply #3 on: October 25, 2010, 08:59:51 PM »
SYE's are designed to use a CV style rear driveshaft (double-cardan).  The Yoke included with the SYE is specific to a CV driveshaft.
You want the pinion inline with the driveshaft and use a CV shaft.
