Author Topic: Powertrax No-Slip Installation Help  (Read 2729 times)
redYJrider
« on: October 25, 2010, 01:06:07 PM »
I'm gettin ready to install a used Powertrax No-Slip into the rear of my 90YJ. I'm missing the check block though. Does anyone know the dimensions of this check block? I can't seem to get a response from Richmond Gear.    :brick:
« Last Edit: October 25, 2010, 01:07:24 PM by redYJrider »
Re: Powertrax No-Slip Installation Help
« Reply #1 on: October 25, 2010, 01:18:03 PM »
Did you try contacting the place you bought the locker from?
redYJrider
« Reply #2 on: October 25, 2010, 01:28:15 PM »
Ebayer wasn't familier with it.
« Reply #3 on: October 25, 2010, 01:36:34 PM »
Was it used?  In any case I'd call Richmond Gears if you haven't already.  Emails don't always get checked.
redYJrider
« Reply #4 on: October 25, 2010, 01:56:26 PM »
Yes it's used. I'll try calling Richmond Gear again in a little while.
« Reply #5 on: October 25, 2010, 03:15:38 PM »
powertrax 92-0435-2705 for d35 1990-1993. got the same locker in my jeep pulled out the checker from the box and got these dimensions.
wide side(max allowable): 0.165 in
thin side (minimum allowable): 0.132 in
hope this helps
« Last Edit: October 25, 2010, 03:19:51 PM by chardrc »
redYJrider
« Reply #6 on: October 25, 2010, 03:32:12 PM »
hope this helps
That's what I'm looking for. Thank you!
