Author Topic: What spark plugs for my 2001 4 banger  (Read 6069 times)
Offline andpgud
Re: What spark plugs for my 2001 4 banger
« Reply #15 on: November 29, 2010, 02:44:36 AM »
I asked because I got this answer on another forum. My car is a 2001
I think that only applies to systems with distributors, but every Jeep after 2000 has a DIS (Distributorless Ingnition System) and the double platinum plugs tend to last longer then copper plugs do because a DIS sends the spark more often..just make sure you get DOUBLE platinum. You can go with copper too but they will wear out quicker
« Reply #16 on: November 29, 2010, 08:12:19 AM »
I'm pretty sure that applies to the 4.0L engines. I can't see how the spark can be send to the plug more often unless it's a wasted spark system, i don't think that's the case with the Chrysler PCM in question (but can't tell you first hand).
« Reply #17 on: November 29, 2010, 08:51:14 AM »
Jeeps are just not high strung enough to be that sensitive to plugs,
Autolight or NGK (You can go Platinum if you have a burning desire to spend money)
But IN the jeeps I know of  the platinums have NOT lasted well.
Despite being a long time Bosche plug user I don't use them in my jeep,
they simply did not last as long and for some reason I eat plug wires with them...(No clue why)
I suspect they are slightly higher resistance than the NGK's... But no proof..
« Reply #18 on: November 29, 2010, 12:50:46 PM »
DIS was only used in the 4.0L.  The reason they went with the double platinum is because the DIS is a high-amp system.  I believe they have 3 coils/ballasts, in which each pair share one coil.  The 2.5L does not have this.
I'm not sure if the DIS sends multiple sparks or not though.  I know the MSD ignition does.  This is to help scavenge more power with more complete burn.  Although, you can do the same by increasing the spark plug gap and having a longer arc with an aftermarket coil.
« Reply #19 on: November 29, 2010, 08:58:34 PM »
Also most CDI systems only multi spark to 3000 or 3500 RPM after that its one spark...
Dylan
« Reply #20 on: November 30, 2010, 04:36:52 PM »
I've had nothing but good experiences with Bosch single platinums in my 2000 since I swapped out the original plugs at 12k miles... over 132k now and no complaints.  The only plugs I've ever had a bad experience with over the past 18 years I've been driving has been with NGK - picked up a set since they were supposedly the hot thing going at the time, two of them went completely dead in a month, haven't touched 'em since.
« Reply #21 on: December 01, 2010, 12:28:00 AM »
Its all in the luck and which plug if ya ask  me....
I've tried 3 different versions of the platinums in my 94 and none of them made 12K...
ON the other hand the NGK copper core standards last me about 45K a set.
I ran Platinums in a Toyota and same issues, but they worked great in my old
Porsche when running regular gas, when running unleaded they toasted quickly...
I wonder if its the crappy gas in oregon? Lots of alcohol and additives...
Offline MarkyB
« Reply #22 on: December 01, 2010, 06:41:26 PM »
I'm currently running the Bosch Platinum 2s and they are fine,
so far.
quicksand
« Reply #23 on: December 01, 2010, 11:48:25 PM »
I have beening runnig NGKs V Groove on mine for 8 to 9 years now. No not the same ones. But in the past I have used bosch platniums with the 2 and the 4 pronger thinga migige, I also used regular champion copper, O a nightmare with E3s almost blew up my motor, stay away from those. Eiether way I always keep coming back to the NGK V Groove. They work best for me. I do run a accel coil which is rated at 48,000 volts, I also run accel 8mm wires. I found my sweet spot with the plugs gapped at .037. Remember as they burn or wear out the gap gets bigger. I do pulled them out about every 4 months or so, clean them and regap for optimum performance.
