Author Topic: 97 TJ fuel cell question  (Read 5004 times)
BatesOffroad
« on: November 27, 2010, 04:32:34 PM »
Ok I've got a 97 TJ my plans are stretch the rear axle back 5".  So I need to replace the fuel tank and there is no way I'm gonna spend $1000 to do that. I just want to buy a fuel cell and pump. But what pump should I buy to get the correct fuel pressure?
« Last Edit: November 27, 2010, 06:16:06 PM by Jeffy »
Re: 97 TJ fuel cell question
« Reply #2 on: November 28, 2010, 12:28:04 AM »
That ring works well, my buddy used in on the stretch tank he made himself, darn thing is expensive though, Gen Right wants over 200 bones for it
BatesOffroad
« Reply #3 on: November 28, 2010, 09:16:10 AM »
I dont know why I never thought of that I serched all day yesterday for ideas. I even seen the threaded ring on genrights site! :puzzled: I think thats what I'll do those street rod cells look like they fit perfect.
Thanks for the info guys!
« Reply #4 on: November 28, 2010, 12:35:35 PM »
If you don't have a back seat and want more fuel there is a 30x12x12 that's 19Gallons.
I think there are a few guy's on Pirate4x4 who make different TJ rings.
BatesOffroad
« Reply #5 on: November 28, 2010, 01:34:01 PM »
Yeah I tossed the back seat long ago.. coudnt fit my cooler in there :wine: I did some 1ton build searchng on pirate and found a guy who does them up i didnt pm him yet to see how much though! I post it up when i find out for sure.
« Reply #6 on: November 29, 2010, 08:48:44 PM »
What makes the TJ setup special? Seems like its cheaper to buy another pump and just use through fitting mounts.
Is the TJ fuel pressure same as a YJ?
« Reply #7 on: November 29, 2010, 08:54:58 PM »
That's what I'd do.  No need for the stupid all-in-one sender.
« Reply #8 on: November 29, 2010, 08:59:40 PM »
I believe RCI has a solid state fuel guage thats adjustable as well.
Just goes through a vent bug in the tank.
« Reply #9 on: November 29, 2010, 09:49:32 PM »
Yup, comes with one but the sender won't work with the Jeeps.  You'd need a new sender or gauge.
« Reply #10 on: November 29, 2010, 11:39:49 PM »
TJ has the FPR integrated and is 49psi, YJ has the FPR on the injector rail and sits at 39psi.
« Reply #11 on: November 30, 2010, 12:32:57 PM »
It would be pretty simple to add an inline FPR though.  You would also need to add a fuel filter IIRC.
« Reply #12 on: November 30, 2010, 12:47:30 PM »
yep, that should be simple if you go with a custom thank, you need a return back in the tank that's all.
