Author Topic: Outside the box front end  (Read 7969 times)
drunkencityworker
Re: Outside the box front end
« Reply #15 on: December 04, 2010, 09:08:40 AM »
I had seen that the JK had a larger pinion. But I havnt seen that it had larger shafts. I know its beefier than the tj 44. But havnt heard its tougher than a ford HP 44. Do you have a souce or link for that
blacknblue
« Reply #16 on: December 04, 2010, 05:33:47 PM »
I just saw some beefy axle trusses at T&T Customs.....http://tntcustoms.com/axletrusses.aspx
« Reply #17 on: December 04, 2010, 08:03:51 PM »
For an HP Dana 44 you can get the fancy CV axle shafts but they do not come cheap.
The stock stuff is about as skimpy as a dana 30, 27 spline axle shaft
See here for comparison
The JK Dana 44's seem to live with 37 and 39" tires if you do not go completely nuts
A friend of mine went through about 4 or 5 warn stub shafts on a Hi Pinion Dana 44 is a period of about 4-5 months on 37" Krawlers with a Chevy 350 in his TJ
« Last Edit: December 04, 2010, 08:06:37 PM by aw12345 »
drunkencityworker
« Reply #18 on: December 06, 2010, 04:59:17 AM »
whats the width of a jk front 44
« Reply #19 on: December 06, 2010, 09:20:16 AM »
The JK D44 has larger u-joints too.  What I've read is that they do have to be gusseted and sleeved and have the ball joints upgraded before any really heavy use.
« Reply #20 on: December 06, 2010, 12:47:50 PM »
66 and change IIRC.  Keep in mind it's 5 on 5" if you get a Rubicon axle.  The J8 Axles are 5 on 5.5".
*** Looked up the exact, it's 65.375".
« Last Edit: December 06, 2010, 12:58:50 PM by Jeffy »
drunkencityworker
« Reply #21 on: December 06, 2010, 01:41:40 PM »
But they do sell them to use dana 30 outers
« Reply #22 on: December 06, 2010, 02:40:20 PM »
JK D30 outers.  Not sure if they're the same as TJ/XJ/YJ
DodgeMudder
« Reply #23 on: December 06, 2010, 04:24:17 PM »
Here's a really out side the box front end build up for you:  Use a '79 Ford HP 44 center cut to waggy width and using Waggy inner shafts (chromo replacements for better strength) Use '74-'80 Dodge outer flat top knuckles they are a flat top knukle with a rebuildable unit bearing, and 5 on 4.5 bolt pattern.  Now if you want to have manual hubs instead of the unit bearings MileMarker makes them and they are cheaper than the Jeep hub conversions.
This is an idea I've been thinking about building for a while.
« Reply #24 on: December 06, 2010, 06:54:52 PM »
Did a little poking around.  You will run into issues with the JK U-joints.  The JK uses 1350 u-joints.  I've also heard that the ball-joints are larger as well.
« Reply #25 on: December 06, 2010, 07:04:02 PM »
Or go Dana 44 center housing with dana 60 outer ends.
No matter how you look at it, a good reliable front end that is strong will cost some money.
drunkencityworker
« Reply #26 on: December 08, 2010, 05:19:15 AM »
can my beads be drilled to fit 5x5.5
« Reply #27 on: December 08, 2010, 06:42:25 AM »
Use spacers makes it a bit wide in front or buy take of JK rims, plenty of those to go around
« Reply #28 on: December 08, 2010, 01:59:55 PM »
You don't want to be drilling wheels.  Getting them centered is hard enough.  Sell them and get new ones if you have to.  You could also use spacers that have different patterns but that's always not optimal.
BTW: 5.5"?  If you're talking about the JK then it's 5".  J8 stuff is 5.5" which is the same for CJ's as well many others.  5" is just Chrysler/Dodge/Jeep, I think.
« Reply #29 on: December 08, 2010, 04:51:28 PM »
he might be able to but depends if it's centered on the hub rather than the lugs and if he has enough meat (or seating if you wish) behind the new locations (I can't remember if he's got humvee recentered wheels or not, if he does probably he can call the guy that sells them he would know for sure). I had redrilled rims but they were cast alloys and were centering on the hub, they worked well with no issues but they were fairly thick and there were only 4 holes rather than 5 so the holes were further apart (you would end up with 10 holes in this case).
