Author Topic: Relay question  (Read 1917 times)
Relay question
« on: December 03, 2010, 09:51:49 AM »
So one of the KC lights' relayed has died on me (probably had something to do with the fact that it was under water last time I wheeled!), and I cannot get an exact match; I was wondering if i used a 12V one instead of a 14V one if it would work (it's a Bosch, not a cheap chinese one)?
Re: Relay question
« Reply #1 on: December 03, 2010, 11:56:19 AM »
12v is fine, match the amps though.
Re: Relay question
« Reply #2 on: December 03, 2010, 12:41:08 PM »
14V is an odd rating.  Either match the rating or go higher.  Usually Bosch/Tyco relays are 30A, 30/40a or 40A.  Also if your harness uses pin 87 and 87a you will need to use a 5-pin relay and not a 4-pin.
« Last Edit: December 03, 2010, 12:41:37 PM by Jeffy »
Re: Relay question
« Reply #3 on: December 03, 2010, 01:42:50 PM »
the 5 pin is for normally closed (when not activated) - he doesn't need that for the lights.
Re: Relay question
« Reply #4 on: December 04, 2010, 01:37:40 PM »
The original was a 14V 40A; I ended up using a 12V 30A, but since I also changed the bulbs from 100W to 55W, I should be good to go (55W/12V=4.58A, times 2, it should be a bit under 10A of actual (theoretical) draw; leaves 20A of cushion!).
