Author Topic: Scout D44's?  (Read 1892 times)
Offline lokitim
Scout D44's?
« on: December 05, 2010, 10:29:59 AM »
I found some d44 axles from a 4 cyl scout, 2 rear & 1 front - $250, not sure what year. From what I read on here, these will work on a YJ, am I correct?
Thanks
1993 YJ, 4cyl, AX15 5spd,  J20 3/4 ton axles, SOA with stock springs, disc brakes on all fours, hi-steer, flat tops,33x12.50 General Grabbers on beadlocks,Warn Front Bumper, Smittybilt w/swing away tire mount rear bumper, custom Hi-Lift Mount, Bedliner interior & body sides, Flush mount tail/backups
Re: Scout D44's?
« Reply #1 on: December 05, 2010, 02:01:28 PM »
The rear would work but the front won't since it has a passenger side drop. The cool thing about Scout D44's is that the carrier is offset so the axle shafts are identical.
Offline lokitim
Re: Scout D44's?
« Reply #2 on: December 05, 2010, 03:14:50 PM »
Thanks. I also found a set from a late scout II, looks like - in pic - it has drivers side drop. I hope to get an answer from the guy soon - $500 for pair.
Re: Scout D44's?
« Reply #3 on: December 05, 2010, 03:17:55 PM »
You sure the axle isn't just upside down?
Offline lokitim
Re: Scout D44's?
« Reply #4 on: December 05, 2010, 04:53:14 PM »
Yea, thanks for the info. I'll keep looking....
