Author Topic: Floor Jacks  (Read 2558 times)
Offline 95 Lowbuck
Floor Jacks
« on: January 02, 2011, 07:05:59 PM »
Who makes a decent floor jack these days ?
I had made due with the cheep 2 1/2 Ton models
that you can get at your local chain auto parts stores.
Then I bought a Ford Excursion and needed to upgrade. (7200 lbs)
I bought a 3 1/2 ton Sears floor jack which I thought would be a quality product.
Would barely lift one end of the truck but worked OK.
Two years and a big pool of oil later I'm left with a crap floor jack
that does not work, out of warrenty, and is not rebuildable. (not even a port to refill)
Sears also sells an American Forge 3 1/2 ton they say is professional grade,
Any ideas?
Re: Floor Jacks
« Reply #1 on: January 02, 2011, 08:53:27 PM »
Sounds like there was air in the jack or else bad seals.  Strange that there is no fill hole.
I use an old Harbor Freight 2.5T jack.  Looks exactly like the 3T they make now.  The only real complaint is that I with it had a rapid rise.  I hate pumping the handle with limited room.   I've had it for over 10 years though.
Lots of people have these: http://www.harborfreight.com/3-ton-super-heavy-duty-floor-jack-34271.html
Re: Floor Jacks
« Reply #2 on: January 02, 2011, 09:15:07 PM »
Any ideas?
i think we had the same jack, heavy as heck craftsman that never quite worked right and craped out right as the warranty expired,... lots of review online show a similar story...
Offline 95 Lowbuck
Re: Floor Jacks
« Reply #3 on: January 03, 2011, 06:59:31 PM »
Wish I had read the reviews before I bought it.
I did end up buying the H.F. 3 ton and I'm pretty happy with it.
Held my Ford up for 15 min. and did not budge.
At $80.00 bucks it's hard to complain.
« Last Edit: January 03, 2011, 07:02:45 PM by 95 Lowbuck »
Re: Floor Jacks
« Reply #4 on: January 03, 2011, 07:29:11 PM »
You might check for a 20% coupon.  They turn up regularly.
