Author Topic: Advice needed  (Read 10209 times)
4BangerTJ
Advice needed
« on: January 13, 2011, 02:25:29 PM »
Ok I'm new to this so I figured I would just come right out and ask for advice. Just bought my first jeep. Its a 99 wrangler. I want to lift it but want to know what height and brand you guys recommend. Also what size wheels and tires. I did away with my lifted tahoe in search of something that can b driven on more than just mild paths and mud but don't ever plan on going anything more than mild nothing crazy and it will be my daily. I do want that big beefy look that I have always envyed of jeeps. So shoot. and tell me what cha think. Thanks
Re: Advice needed
« Reply #1 on: January 13, 2011, 03:05:55 PM »
Well, if I had to start over again, I'd probably go with a 3" Rubicon Express lift with 33x10.5R15's.  It should be enough to get you through 90% of the trails without much trouble while still giving you the ability to drive it daily and still have decent highway manors.
4BangerTJ
Re: Advice needed
« Reply #2 on: January 13, 2011, 03:47:24 PM »
Can you tell me why exactly you like the rubicon lift over others and why only 33s and nothing larger? Just curious cause I thought larger tires were better off road and assumed that 4-6 inches was the ideal lift height. Not trying to say you don't know your stuff just wanna know why cause likei said I'm used to my lifted tahoe where clearance is the main issue so the more lift and bigger tires the better. Also what do you think of body lifts?
Offline VA_YJ
  • Now I need a CJ...
Re: Advice needed
« Reply #3 on: January 13, 2011, 03:53:01 PM »
Jeffy's right on target.  The open diff Dana 35 tends to have issues with tires over 33'' and once you hit about 4" of lift on a TJ, you need to consider a long arm set-up, plus rear driveshaft vibration issues are more common.  The 3" lift with 33s gives you a lot of go for not much dough, and maintains good road manners.  You might also consider installing a winch after you get the lift and tires in place - good bang for the buck.  The 33x10.5s give you ground clearance without destroying your gas mileage.  If you want strong performance, you'll want to regear to 4.88 at some point down the road, but this can wait.
Re: Advice needed
« Reply #4 on: January 13, 2011, 04:10:34 PM »
You could go for more lift and larger tires but you better have deep pockets.  You are compromising onroad for offroad.  Like what VA said, once you get over 33" you start having to replace a lot more parts.  Not to mention regearing which costs a lot.
Your Jeep is a lot lighter then your friend's Tahoe.  Live-axles are preferred over IFS.  Tires, wheel and lift will probably set you back around $3000.  Regearing will cost another $1500-2200 if you have a shop do it.  If you're lucky you can get a shop to do it for about $200 in labor.  But you'll still be spending around $400 in parts.  More lift will also require you to get a SYE and rear driveshaft $500-700 (you install).  The rear axle isn't the greatest and if you're going to go with something over 33" then you will need to replace it.  35's and up require lower gears then the stock axles can handle so you're looking at two new axles if you want to regear it properly.  You can see this snowballs very fast.
Offline VA_YJ
Re: Advice needed
« Reply #5 on: January 13, 2011, 04:15:34 PM »
RE has well engineered kits that flex (articulate) well and they also have good customer support.  The RE kits bolt-in, so you don't have to weld much.
Body lifts will give you clearance, but don't help with suspension articulation.  Also, you run into lalignment issues - steering, radiator/fan, shifters, etc.
Let me tell you about my 98 TJ - I bought it cheap because the previous owner destroyed the rear axle with 35" tires.  The Dana 35 (rear) is a light duty axle.  The 4" short arm drove poorly due to suspension angles.   I am in the process of installing a Clayton long arm suspension (welding required), Ford 8.8 rear axle, and Atlas 5:1 transfer to correct all the issues from the previous destruction and give me lower gearing.  Hey, the 1" body lift is good for one thing - I didn't have to hammer the floorboard to get the Atlas in there!
4BangerTJ
Re: Advice needed
« Reply #6 on: January 13, 2011, 04:38:31 PM »
I get what you guys are saying as far as the strength of the axle is concerned. As for affording stuff I do get stuff a lot cheaper than average ie lifts tires wheels parts etc as I manage a shop and have a ton of commercial accounts and also free labor. I don't really think I wanna go the route of changing axles and stuff out cause that's just a lot of work I don't wanna do at least not right now. So a 3inch lift and 33s huh? I will be honest my only concern is it won't be enough lift to do what I wanna do cause I wanna try more challenging stuff than I did in my tahoe and I also want it to be tall enough that I am ok with it appearance wise. Can you go through some pretty challening mud and rock crawling with that? And what does it look like all done? thanks
Offline 95 Lowbuck
Re: Advice needed
« Reply #7 on: January 13, 2011, 05:27:00 PM »
I totaly agree with all these responces.
You can have alot of fun with a mild lift, some type of locker, and 33" tires.
More than enough to do 90% of the trails out here in California.
The  little 4banger will never make a great mud bogger, but they make
great rock crawlers and trail machines.
And if geared right a good commuter. (4.88's)
Castr8r
Re: Advice needed
« Reply #8 on: January 13, 2011, 08:01:33 PM »
     When I was in Moab last spring, I did Flat Iron Mesa trail backwards.  Forward, it is a 5 and backwards it is an 8.  This was on 33" BFG MTs and a little four-banger.  The two guides were talking while we were on the Kane Creek Trail and agreed that a Jeep with 33s, a good spotter, and a good attitude could run any trail in the Moab area.  Between them, they had over 50 years experience guiding in Moab.  33s ought to be good enough.
Re: Advice needed
« Reply #9 on: January 13, 2011, 08:33:45 PM »
I think he's really underestimating the capabilities of the Jeep.  Some time behind the wheel time would solve that though.  There is some support for Jeeps 'Trail Rated' badge.  Jeep runs the Rubicon Trail, here in CA, unofficially.  Before it was official but now it's not.  They have been doing this since the 90's.  Stock YJ's and then slightly modified YJ's with 31's were used and continued to be used by Jeep Jamboree for official use as well as running Dealers across the trail.  This continued with the TJ, Liberty, Grand Cherokee, Commander, etc...
33's are pretty common on Jeeps since the early days.  Keep in mind that the new JK's come with 32's on the Rubicon's.  35's are nice but aren't really required.  Yes, they make the trail easier BUT they also require a lot more work to get setup right.
http://www.youtube.com/results?search_query=rubicon+trail+jeep&aq=f
As long as you're not doing some trails like the CA's Hammers (check out Art's TJ build) AZ's Ajax, etc...  you'll be fine.  For most trails 33's are fine.
Re: Advice needed
« Reply #10 on: January 13, 2011, 08:53:16 PM »
i agree with Jeffy for a 3" lift and 33s. That formula is considered to be best for all-around use by many 4x4 experts. If you are tight on cash you may want to look at Rough Country lifts. they make a 3.25" and 3.75" kit. I have the 2.5" and am upgrading to 3.25". Considering the price, i think it's one of the best deals. there are extensive reviews online (Jeepforum and others). Of course if $$ is not a problem, some consider the best to be an Old Man Emu set up. to do it right, you would have to contact them and have a tech set up a good lift for ya.
By the way, for light wheeling, a little mud, "nothing crazy" as you say, a good set of 31" MTs will do just fine. I ran a set for almost 3yrs before upgrading to 33s.
4BangerTJ
Re: Advice needed
« Reply #11 on: January 14, 2011, 06:41:03 AM »
You guys are becoming more and more convincing. And you are right that I am probably underestimating a jeeps capabilities as I have never owned one but always seens pics of them crawling and such and wanted to do it. Maybe I will go do some wheeling a bit before I lift it jus to see what the stock capabilities are so that I have a rough idea. Then maybe look into hitting up a 3 in lift and some 33inch MTs. I guess my only concern left is what it will look like. Is there a section on here for like pics of members rides where I can see what it may look like? thanks a lot for the advice guys.
DodgeMudder
Re: Advice needed
« Reply #12 on: January 14, 2011, 08:47:53 AM »
This is a great starting point, add in a good set of rocker gaurds and some better skid plates, and think about some corner gaurds, add some good tires, either 30 or 31's and wheel it, get a good feel for it, and see from there if you want to go higher.  I know a bunch of people who have gone hog wild and built huge Jeeps but because they don't know how to wheel it they don't go down a trail as well as a smaller rig.  I would say a 1" body lift w/ mm lift and flat skid, 3" lift, 33's, and a locker or two are going to give you one of the best combos for an all around Jeep you can get.
As far as deep mud, a wider tire on the light little Jeeps will let them run with the big boys, because the Jeep is light it doesn't sink in like a fullsize so it doesn't need the tire size the fullsizes do.
Re: Advice needed
« Reply #13 on: January 14, 2011, 09:29:44 AM »
Mine is a YJ, so it's a bit different, but I run the D35 and D30 (stock axles but with alloy shafts and lockers) with 33's, and I have gotten through some tough terrain with this combo...  Here are some examples:
<a href="http://www.youtube.com/v/Y99Pgq0MgX0?fs=1&amp;amp;hl=en_US" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/Y99Pgq0MgX0?fs=1&amp;amp;hl=en_US</a>
<a href="http://www.youtube.com/v/vIom32ggZM4?fs=1&amp;amp;hl=en_US" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/vIom32ggZM4?fs=1&amp;amp;hl=en_US</a>
<a href="http://www.youtube.com/v/PNtmAvqf9Uc?fs=1&amp;amp;hl=en_US" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/PNtmAvqf9Uc?fs=1&amp;amp;hl=en_US</a>
Oh, and how's this for thick mud?  There's a 33" BFG KM2 under all that...
Some more mud:
<a href="http://www.youtube.com/v/WCAHc5TEOYA?hl=en&amp;fs=1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/WCAHc5TEOYA?hl=en&amp;fs=1</a>
An interesting ledge:
<a href="http://www.youtube.com/v/lsNmLKtDazQ&amp;hl=en&amp;fs=1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/lsNmLKtDazQ&amp;hl=en&amp;fs=1</a>
And some river fording:
<a href="http://www.youtube.com/v/1gtKTpg1uBs&amp;hl=en_US&amp;fs=1&amp;" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/1gtKTpg1uBs&amp;hl=en_US&amp;fs=1&amp;</a>
 We dont get many rocks here in Costa Rica, but with 33's (and sometimes with the help of tire chains and my winch), I get through most of the obstacles the guys with 38's go through...  in fact, i have yet to be left behind because I cannot get through (I have opted out of some obstacles because i dont want to tear my Jeep apart with body damage, but I am sure it would have gone through!).
Dont underestimate the Jeep on 33's!
Felipe
« Last Edit: January 14, 2011, 09:31:04 AM by jfrabat »
Re: Advice needed
« Reply #14 on: January 14, 2011, 10:26:25 AM »
Also, a member of this forum did the Rubicon Trail in a YJ on 31s and a very small lift.  Properly driven, Jeeps with relatively mild modifications can do amazing things.
« Last Edit: January 14, 2011, 10:26:44 AM by neale_rs »
