Author Topic: I have MANUAL steering , will adding a second stabilizer help?  (Read 3317 times)
95yj0645
« on: January 14, 2011, 12:36:15 PM »
I have manual steering and you can feel the wheel shake when going higher speeds example 65-70.  All of my joints and bearings are good on the entire jeep .. I think its just because its manual steering.. I have onw stabilizer shock on it now will adding a second help me out ? also I have a 2.5" lift do I need a drop pitman arm ?? If so how much drop do I need
Re: I have MANUAL steering , will adding a second stabilizer help?
« Reply #1 on: January 14, 2011, 12:38:46 PM »
I don't think just being manual is the problem.  It must be something else, wheel balance, alignment, etc.
« Reply #2 on: January 14, 2011, 12:42:22 PM »
All the steering dampener will do is mask the underlying problem.  If you feel a vibration it could be in the tires.  If you have a locker it could be from the front driveshaft as well.
95yj0645
« Reply #3 on: January 14, 2011, 12:52:17 PM »
I dont have a locker .. and the tire shimmy is in 2wd when the front shaft isnt spinning, Im looking at the skyjacker kit or the trailmaster kit.  I like my manual steering for simplicity purposes I just want it to be smoother and easier to turn, will that kit help? also I plan on getting my tires rotated and balanced
« Reply #4 on: January 14, 2011, 01:02:25 PM »
No lift kit is going to make the steering smoother.  If you want easier to turn stick with smaller tires or else go with PS.
« Reply #5 on: January 14, 2011, 01:59:23 PM »
I run power steering on my yj it's very basic. pump and 2 lines. it would be a huge deal to convert.
you will want it when you go bigger tires and lift for sure..
« Reply #6 on: January 14, 2011, 03:03:24 PM »
I think that's supposed to say, 'it wouldn't be a huge deal..."
« Reply #7 on: January 14, 2011, 04:46:50 PM »
thanks Jeffy lol ya thats what it's suppose to be. I think I got interrupted in the middle of that post to be honest lol
« Reply #8 on: January 14, 2011, 04:47:44 PM »
this is worse than my fuel/oil mixup  :wall:
« Reply #9 on: January 14, 2011, 11:06:14 PM »
Balancing the tires should help if that is the problem. If your tires are cupped from lack of rotation that will also cause vibes.
95yj0645
« Reply #10 on: January 14, 2011, 11:40:16 PM »
all good places to start .. so a dual stabilizer is pointless?
Dylan
« Reply #11 on: January 15, 2011, 05:22:01 AM »
Does throwing a second diaper on a kid who stuffed their shorts make sense?   :crap:
« Reply #12 on: January 15, 2011, 08:35:24 AM »
mahahaha ya we all do it once and a while lol
I didn't take it to heart sharp more was a good laugh lol
« Reply #13 on: January 15, 2011, 08:37:34 AM »
ya. if anything just get a heavy duty one but only need one
probably won't fix your problem though. you should be able to run without it without vibrations it only helps with bump steer. it slows the steering if you hit something it dampens it.
95yj0645
« Reply #14 on: January 19, 2011, 06:33:51 PM »
Rotated tires .. Rides smooth as glass now ..took it up to 70 mph no more shimmy
