Author Topic: Xrc8 winch issue  (Read 4227 times)
95yj0645
Xrc8 winch issue
« on: January 24, 2011, 09:25:50 PM »
I have a smittybilt xrc8 winch and it isnt working .. its seriously been used twice since I bought it so its brand new .. currently temps are very cold and we have snow .. a guy slid off the road so i was going to winch him out but once I plugged in the controller it was no go .. did i fry my switch?when i push up to spool out the red light blinks for a split second then goes off with a flash of green.. when i push down to spool in the green light flicks on for a second then off with a flash of red .. you DO NOT hear the solenoid click on either time. i took an awesome detailed vid on my ipod but it wont load to youtube it would make this so much easier to explain
Re: Xrc8 winch issue
« Reply #1 on: January 24, 2011, 10:20:13 PM »
Hmm, there really isn't much to a winch.  Although if it was a solenoid, then you should still have one direction working normally.  I'd suspect the controller.  I'd need to see a schematic to se able to see what the controller actually does though.  Blinky lights seems weird.
Found this:  http://www.outhouseoffroad.com/tech.html
You can use it to make a jumper to bypass the controller and see if the winch works.  it's also a good idea to have a dash controller as well as people are always losing the controllers.
95yj0645
« Reply #2 on: January 25, 2011, 04:18:46 AM »
Got my vid to upload just waiting for approval now.. Jeffy awesome link!! That's freakin cool only thing I wouldn't like is for spoiling the winch up
95yj0645
« Reply #4 on: January 25, 2011, 12:43:25 PM »
http://m.youtube.com/index?desktop_uri=%2F&gl=US#/watch?xl=xl_blazer&v=UAShBKePyqU
That link doesn't work.  It's also the mobile link.  What's your user name?  I tried xl_blazer but it's not showing anything.
95yj0645
« Reply #5 on: January 25, 2011, 01:20:06 PM »
<a href="http://www.youtube.com/v/UAShBKePyqU" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/UAShBKePyqU</a>
« Last Edit: January 25, 2011, 01:52:57 PM by Jeffy »
95yj0645
« Reply #6 on: January 25, 2011, 01:20:44 PM »
lets try that
« Reply #7 on: January 25, 2011, 02:02:41 PM »
Hmm, after looking at some of the pictures, I suspect it's the solenoid.  I guess they went cheap and instead of using 4 robust yet simple solenoids they went with some small controller.  Probably need to call Smittybilt or whoever owns them now and have them send a replacement or else you could build a standard solenoid pack.
