Author Topic: Dana 50 gears in your HP D44.  (Read 2810 times)
« on: January 27, 2011, 11:07:13 PM »
Re: Dana 50 gears in your HP D44.
« Reply #1 on: January 28, 2011, 12:09:38 PM »
Pretty cool stuff these guys are doing.   I wonder if this mod wouldn't cause the carrier itself to become the weakest link.
« Reply #2 on: January 28, 2011, 01:56:53 PM »
The aftermarket carriers such as ARB and Detroit's are pretty dang strong. Much more than a stock carrier.
« Reply #3 on: January 28, 2011, 05:23:56 PM »
The weak point should still be U-joints or else hubs, if you build the axle right.
« Last Edit: January 28, 2011, 05:24:23 PM by Jeffy »
« Reply #4 on: January 28, 2011, 07:26:53 PM »
Both those can be made stronger. But ya something will give if you push it hard enough. Hubs are pretty quick to change out, or leave it alone and limp out on 3 wheel drive.
« Reply #5 on: January 28, 2011, 07:48:29 PM »
What I mean is that you would normally build one of those into your 'fuse'.
« Reply #6 on: January 28, 2011, 09:29:45 PM »
I know, that's what I meant too.  ;)
