Author Topic: Another 30rh question  (Read 11981 times)
Offline MarkyB
Re: Another 30rh question
« Reply #30 on: May 12, 2011, 05:43:53 AM »
OK,
what about with an adapter?
Offline MarkyB
« Reply #31 on: May 12, 2011, 11:45:57 AM »
rebuild needed. $1400. :brick:
« Reply #32 on: May 12, 2011, 12:12:22 PM »
I suggest getting a 30RH from a boneyard.
Ad for adapters, you could try a 700R4 but it's more then just an adapter.  AW4 would be another option.
« Reply #33 on: May 12, 2011, 12:18:55 PM »
that's very steep, shop around
also, look for a second hand one and might consider looking for a rebuilt with core exchange
i also found this one which you'll need to research if it can be used http://cgi.ebay.com/ebaymotors/Jeep-Cherokee-30RH-A904-Automatic-Transmission-NEW-_W0QQcmdZViewItemQQhashZitem20b93613b6QQitemZ140546282422QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
although is not for the Jeep 4x4 with t-case adapter would be interesting to research if the rear output shaft and housing can be swapped out with yours, transmission is new
EDIT: seems that the only way to swap the output shaft (if it is possible and everything would fit) is to take the transmission apart so not really an easy task (not to mention not knowing if everything is the same) so that's not a good idea although the price is great
« Last Edit: May 12, 2011, 12:27:11 PM by sharpxmen »
Offline MarkyB
« Reply #34 on: May 12, 2011, 07:37:49 PM »
What about a 32RH from a 6cyl. Will that work?
I'll be shopping junkyards.
I am watching that ebay one.  Looks like the tail section bolts on.  but I agree might be too much of a hassle.
« Last Edit: May 12, 2011, 07:39:25 PM by MarkyB »
« Reply #35 on: May 12, 2011, 08:13:39 PM »
The tail of an automatic trans is easy to change the output shaft is not it will require disassembly of the entire transmission.
« Reply #36 on: May 12, 2011, 08:26:46 PM »
i looked in the transmission manual, the output shaft is assembled with the transmission taken apart unfortunately
dunno if the bellhousing from 30RH bolts onto the 32RH, that's the main issue, then it's the converter (bolt pattern, diameter, etc).
Offline MarkyB
« Reply #37 on: May 13, 2011, 02:56:29 PM »
Well, after numerous calls to wrecking yards.
It's going to be $1000 to get a used trans with about 100k on it.
There are 2 in the entire Southeastern US.
« Reply #38 on: May 13, 2011, 03:18:12 PM »
car-part.com
1995 A/T
$450 Action Auto Wreckers USA-CA(San-Jose) 1-800-606-9732
$675 Precision Auto Parts USA-AZ(Phoenix) 1-602-232-5146 1-877-703-3583
1999 A/T
$750 Mike's Foreign Auto Parts USA-CA(Wilmington) 1-800-559-6453 / 310-830-6200
$700 Precision Auto Parts USA-AZ(Phoenix)  1-602-232-5146 1-877-703-3583
$600    Pickup Salvage Incorporated USA-CA(Bakersfield) 1-800-323-1401
for example, doesn't say what model transmission it is. do a search and you can sort by distance based on your zip code.
« Reply #39 on: May 13, 2011, 03:43:26 PM »
car-part.com
1995 A/T
1999 A/T
I think he's in the other SouthEAST.   :wall:
Offline MarkyB
« Reply #40 on: May 13, 2011, 10:18:27 PM »
car-part.com shows bascally the same trannys I was quoted all day.
Prices run $800 then about $200 to ship.
« Reply #41 on: May 13, 2011, 10:51:36 PM »
If you find one local, there should be no shipping.  I HIGHLY recommend not ordering a transmission out of state.  It doesn't matter how good the warranty is, if you have to ship it back and forth, it will kill you.  Hard to imagine someone charging $800 for one that's been salvaged.  I don't think you ever mentioned the year but try different years as well.
Worse come to worst, you could swap in a manual and still save money.
« Last Edit: May 13, 2011, 10:51:52 PM by Jeffy »
« Reply #42 on: May 14, 2011, 12:38:44 AM »
for some reason i read southwestern US, got it now
I'm not sure how you searched
1995
Transmission
Jeep Wrangler 115K TESTED GOOD! 115,000 A 10-62 $375 Gentry Salvage USA-AR(De-Queen) Request_Quote 1-800-426-9133
even with shipping you're good
or maybe this one is in driving distance
1995
Transmission
Jeep Wrangler 2.5,AOD,COL     EC5138 $400 Fagan Auto Parts USA-AL(Piedmont) E-mail 1-800-331-5282
Seems to be quite a few at reasonable prices
1995
Transmission
Jeep Wrangler 4 Cyl- 130,000 A CL050 $550 Max Used Auto Parts USA-NC(Hickory) Request_Quote 1-800-346-8755 1-828-324-7906 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler STOCK NO. 003938018     003938018 $550 Universal Auto Recycling USA-KY(Benton) Request_Quote 1-270-527-3431/1-800-443-8578 Request_Insurance_Quote
1995
Transmission
Jeep Cherokee 4.0L,MT,4X4,TCDK,FLR,WITH 412 107,808 A 100457 $550 B & W Salvage USA-GA(Metter) E-mail 800-284-6626 / 912-685-2250
1995
Transmission
Jeep Cherokee 4.0,MPI,4AT,RWD 156,661 A PH0016 $513 Robert's Engines Inc. USA-NC(Lucama) Request_Quote 1-800-528-6911 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler 2.5L,4WD 94,000   S464P $500 Cockrells Auto Parts USA-KY(Mt.-Sterling) Request_Quote 1-800-633-2441 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler 2.5L,AT,COL,4WD     05A031 $500 431 Auto Parts USA-AL(Alexandria) E-mail 1-800-621-3788
1995
Transmission
Jeep Wrangler 10-05,2.5L,SUT,TESTED 178,759 A 19339 $500 Langston's Used Auto Parts USA-FL(Tampa) Request_Quote 1-813-988-7341 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler 06-10,2.5L,AUT 145,911 A 25118 $500 Langston's Used Auto Parts USA-FL(Tampa) Request_Quote 1-813-988-7341 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler A,2.5L,11-95 151,883 A H23695 $500 Agee's Auto Parts USA-VA(Christiansburg) Request_Quote 540-382-2477 / 800-678-6901 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler 4C,2.5L,AT,2WD     T09371 $450 Cox Truck And Van USA-GA(Moultrie) E-mail 1-800-476-1051
1995
Transmission
Jeep Wrangler 1-95,4X4,2.5,AUTO,COL     110203 $450 Davis Used Auto Parts USA-TN(Tazewell) Request_Quote 1-423-626-3438 1-877-671-3438 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler A,2.5L,11/01/94 162,000 A 9091079C $450 LKQ Preferred USA-AR(Conway) E-mail 1-800-233-3513
1995
Transmission
1995
Transmission
Jeep Wrangler AT MAYBE TEST DRIVE CLEAN TRUCK     001665 $400 Crest Truck Parts USA-GA(Cartersville) E-mail 1-770-382-1595 / 1-800-424-2065
1995
Transmission
Jeep Cherokee 4 Cyl, 4X4 4.0     CHE-4.0 $400 Osceola Auto Salvage USA-FL(Kissimmee) Request_Quote 407-847-0083 Request_Insurance_Quote
1995
Transmission
Jeep Wrangler 115K TESTED GOOD! 115,000 A 10-62 $375 Gentry Salvage USA-AR(De-Queen) Request_Quote 1-800-426-9133 Request_Insurance_Quote
Offline MarkyB
« Reply #43 on: May 14, 2011, 07:19:03 AM »
Maybe its the model year filtering them out?
I didnt get those when I searched.
I didn't think to ask if the torque converter was included?
Offline MarkyB
« Reply #44 on: May 16, 2011, 12:51:33 PM »
Well, I adjusted the rear band, and put some Lucas transmission fix in it.  It is much improved! But not cured.  Maybe that will buy me some time untill a reasonably priced tranny pops up close by.
