Author Topic: fuel gauge  (Read 1332 times)
Offline brokenwrist21
fuel gauge
« on: April 14, 2011, 11:19:12 PM »
has anyone ever had any issues with their fuel gauge? my fuel gauge currently reads about 1/8th tank more than what i really have. i know it has to do with resistance and amps. i just forget exactly how to check everything. it actually annoyes me as i would like my gauge to work correctly. i should mention that, the fuel pump is factory, the tank has only been lowered once to install rear shackles, but nothing electrical was disconnected.
Re: fuel gauge
« Reply #1 on: April 15, 2011, 01:38:00 PM »
There are issues with any of the dash gauges if the circuit board on the back of the guage panel got wet and corroded.
Last time I had my cluster out of the dash I pulled all the connections, cleaned them and used electrical grease to seal
them up as I put the connector back on.. My voltmeter was reading WAY low....
Dave.
