Author Topic: hp dana 44 advice  (Read 4400 times)
drunkencityworker
hp dana 44 advice
« on: April 24, 2011, 10:15:13 PM »
onna try and find a 70s ford housing and cut down to waggy or tj rubi width...any advice or mistakes that I should avoid????
st.chevrolet
Re: hp dana 44 advice
« Reply #1 on: April 25, 2011, 12:35:02 AM »
drunkencityworker
« Reply #2 on: April 25, 2011, 07:56:46 PM »
Is there a difference between rubicon 44 aand waggy 44 inner axles? Is it just length.
« Reply #3 on: April 25, 2011, 10:27:30 PM »
on the rubi only the center housing is D44, the tubes are D35 size or D30 for the front. still the axles are 30 splines but i think is the same bearing and c-clip in the rear as on the D35.
drunkencityworker
« Reply #4 on: April 28, 2011, 02:15:44 PM »
I am looking to cut down a hp ford 44 and the guy i know that does rhem likes to use tj rubi shafts.
« Reply #5 on: April 28, 2011, 02:54:02 PM »
Since you run a V8, you might be a lot happier in the long run with a HP60 out front
The U joints on the axle shafts in a Dana 44 are skimpy for big tires and a V8.
You are going to find that with hard wheelin you can pretty much granate those at will
« Reply #6 on: April 28, 2011, 09:20:45 PM »
What does he use for the outer shafts?
I'm cutting down two HP44's and using stock Waggy shafts.  One for the YJ and one for the MJ :dance:
drunkencityworker
« Reply #7 on: April 30, 2011, 07:42:36 PM »
I am pretty sure chevy or jeep outers and chevy brakes and spindle. They are most all 297 so should work. Hey bounty can u send me a pm with cost for cut down housing empty. You arnt to far of a drive.
Point is to have lockouts as weak link and make for easy trail fix. Damn dana 60too big ffor only 4.5 lift and 35s
« Reply #8 on: May 02, 2011, 11:30:11 AM »
I replied to your PM.  http://www.gds4x4.com/ is the shop that quoted me $300 to remove the inner C's, cut to Waggy width, and weld the C's with proper caster and pinion angle.
« Reply #9 on: May 02, 2011, 06:19:46 PM »
If you set the diff  covers of a dana 44 and a dana 60 side by side the dana 60 pumkin only hangs 1" lower than the dana 44. Is not an unsurmountable difference and it's a heck of a lot stronger. Or have a somewhat exotic axle built, a friend of mine had dana 44's with dana 60m outer ends on it, that is about the best of both worlds
« Reply #10 on: May 02, 2011, 09:37:13 PM »
You can find those in the wild as well.  They're 3/4T Dana 44's.
« Reply #11 on: May 03, 2011, 06:07:41 AM »
Not for the front, you cannot, they all have the skimpy U joints, that is the whole thing big U joints and 35 spline inners and  outers. Buddy of mine granated the stub shafts at will, never killed the lockout or so called fuse though.
« Reply #12 on: May 03, 2011, 09:05:55 AM »
How about a fabbed high pinion 9" with dana 60 outers?  That would be awesome.
Also, the JK dana 44s have bigger u-joints.
« Reply #13 on: May 03, 2011, 10:32:38 AM »
Some custom shops have been making hybrid's for a while.  Ford 9" centers with Dana 60 outers.  They haven't been that popular though.
« Reply #14 on: May 03, 2011, 04:12:21 PM »
The JK Dana 44's seem to be a fairly popular swap these days, time will tell how well they hold up, they have weak tubes and inner C's though
