Author Topic: Which Differentials do you have  (Read 3387 times)
« on: April 29, 2011, 08:13:37 PM »
  By the Faq's I seem to have at least a 44.  Will now need to look much closer and see if the tag is still there.  Know the rear is missing.
« Last Edit: April 29, 2011, 08:15:12 PM by grumpygy »
Re: Which Differentials do you have
« Reply #1 on: April 29, 2011, 09:44:08 PM »
i think you mean axles, the diffs would be locked/open, or by brand (stock, arb, ox, eaton, auburn, etc)
i have D30/D35
most guys here would run an 8.8 or D44 in the rear and the D30 up front
« Reply #2 on: April 29, 2011, 10:09:05 PM »
Ok Axle and by the FAQ on it and my bolt patter my front one seems to be a 44.  Thought it should have been a 30 or 35.
« Reply #3 on: April 29, 2011, 10:31:33 PM »
What year and model Jeep are you referring to?
Offline brokenwrist21
« Reply #4 on: April 30, 2011, 12:34:59 AM »
front d30 open yukon gears, rear ds35 yukon gears and axles detroit soft locker. both geared 4.88
« Reply #5 on: April 30, 2011, 06:42:32 AM »
i think he has a '94 YJ
you're right, stock YJ axles were D30 front D35 rear unless someone upgraded them (maybe previous owner). I don't think any of the YJs came with D44s, the Rubicon TJ had D44 centers but the tubes were same size as D30/D35 and the wheel bolt pattern was the same 5x4.5 (edit: and they had air lockers from the factory)
« Last Edit: April 30, 2011, 06:43:39 AM by sharpxmen »
« Reply #6 on: April 30, 2011, 10:14:21 AM »
Its a 94 YJ as was said.  Was the second owner but I bought it in 94 with under 10,000 on it.  Was owned by a gal and sure she did nothing to it.
Will look in a few for the tag.
« Reply #7 on: April 30, 2011, 11:02:45 AM »
Should be D30/D35 with 4.10's The rear should have a rubber fill plug cap on the diff cover.
« Reply #8 on: April 30, 2011, 11:56:59 AM »
Its a 30 just had to look better.   But the tag really didn't say what it was.  Yep year had a rubber plug.  Needed to know so I could get the new gaskets.
« Reply #9 on: April 30, 2011, 02:55:41 PM »
None of the YJ's came with a D44 front as already stated. The D44's don't have a central disconnect on the passenger side of the axle housing. They have a one piece inner axle. The YJ's and some XJ's had a 2 piece inner axle with the motor assembly.
« Reply #10 on: April 30, 2011, 05:44:35 PM »
I'm curious where you saw this in the FAQ?
« Reply #11 on: April 30, 2011, 07:09:30 PM »
i think he looked and the diff cover bolt pattern link from the faq and made a mistake
« Reply #12 on: May 02, 2011, 08:50:45 PM »
There's a Waggy D44 with vacuum disconnect...
Oh, and I run Super D35 and Super D30 with ARB on both ends (of course, after the last trail run, I killed the ARB compressor, so now I have open diffs until I fix it!)
