Author Topic: steering columns  (Read 1744 times)
Offline brokenwrist21
steering columns
« on: May 03, 2011, 05:50:07 PM »
does any one know if the chevy s10 steering column from like the late 80's early 90's will fit a wrangler. i know they look similar and use similar parts.
Re: steering columns
« Reply #1 on: May 03, 2011, 06:16:05 PM »
Should be the same, at least the major parts.  Jeeps use a GM style column.
« Reply #2 on: May 04, 2011, 12:05:07 AM »
my boss is packing around a tilt column from an s10 and seeing as i dont have tilt steering, my biggest concern was the electrical conection and the mounting flange, and would the jeep ignition cylinder fit in the gm column
« Reply #3 on: May 04, 2011, 10:25:38 AM »
Well if he's got one already out then you should be able to measure it up.  It probably won't be 100% bolt-on.  You might have to disassemble and pin the connectors or else maybe flip them.  I'm not sure what flange they use on the GM's but they do use a Saganaw steering box which is what the Jeep uses.  I know some have swapped S-10 columns into CJ's but I haven't heard of anyone doing it to a YJ.
