Author Topic: Manual guages in dash of YJ (instead of sending unit models)  (Read 1003 times)
Offline frhrwa
has anyone tried or succeeded in installing a manual oil pressure guage in the dash of the YJ? I like the manual vs. the sending unit guages if possible.. thanks. wayne '93 YJ
Re: Manual guages in dash of YJ (instead of sending unit models)
« Reply #1 on: May 06, 2011, 03:05:52 PM »
I haven't tried it but keep in mind that the gauges are one unit back there.  You can't just remove one and leave the rest (maybe you can but you would need to cut the unit to fit the new gauge, set up some jumper wires, etc.  Everything needed to replace the gauges is available through vendors like 4wd or Quadratec.
