Author Topic: cherokee ecm swap?  (Read 2482 times)
bigcountry333
cherokee ecm swap?
« on: May 14, 2011, 12:33:06 PM »
ive been doing a lot of reading on the 2.5 lately. seems that the cherokees from 91-95 were rated 20 hp higher than the wranglers. cams are the same so that leaves the ecm's. i would assume the ecms are different because it would be illogical for anything else to be diff.
Re: cherokee ecm swap?
« Reply #1 on: May 14, 2011, 01:35:46 PM »
the difference was 9HP and 4ftlb of torque, and you're right it's the PCM fuel curve in open loop that probably was the reason. You can compensate for that with more fuel (pressure or injectors or both) and no need to replace the PCM. I'm not sure if the airbox was different or not in terms of the restrictor tube you find in the YJ airbox in the outlet - that could also limit the output of the engine, most guys already removed that and went to a 4.0 t/b if not larger.
bigcountry333
« Reply #2 on: May 14, 2011, 02:58:00 PM »
thanks, kinda figured the figures were a little massaged.
« Reply #3 on: May 14, 2011, 03:25:04 PM »
compared to the carburetted one was 25HP more. One difference though, apparently in the XJ version compression was a tad higher (not by much, i can't confirm but probably depending on the pistons could have been 9.2 or 9.4, or maybe a thinner cyl head gasket), YJ was at 9.1:1
« Reply #4 on: May 14, 2011, 05:09:54 PM »
yj mpfi 9.1:1
xj mpfi 9.2:1 91-95
tbi all 9.2:1 87-90
according to allpar
http://www.allpar.com/mopar/amc-25.html
« Last Edit: May 14, 2011, 05:12:04 PM by chardrc »
« Reply #5 on: May 14, 2011, 05:49:05 PM »
yj mpfi 9.1:1
xj mpfi 9.2:1 91-95
tbi all 9.2:1 87-90
according to allpar
I saw that but if you look at replacement pistons they are from 9.2 to 9.4 resulting CR based on dish volume and compression height, so that's why i said i'm not sure.
