Author Topic: New Mods did not work out right  (Read 6575 times)
Re: New Mods did not work out right
« Reply #15 on: May 28, 2011, 06:08:51 PM »
 Connectors were great.  But did notice that At Idle the fumes had my eyes watering.  So today was the 1st day I had enough time between rain showers to change the Injectors back to the stock ones.
  That did it she is running great now.  :clap:
  Still have things to do like the fan Conversion when parts get here and to finish cleaning the inside.  Hook the stereo back up.
« Reply #16 on: May 28, 2011, 06:31:34 PM »
Well I just compared my Injector with the FAQ's  on Injectors.  It looks just like the Ford #24 truck Injector.  It was supposed to be #19.  Are there any markings on them I should look for.
« Reply #17 on: May 28, 2011, 07:15:34 PM »
the p/n you posted I found it listed as the "19#" which are 18.25lb/hr@43.5psi
you said they are new so unless the p/n is different not sure what to tell you. Are they yellow 4 nozzle bosch injectors?
« Reply #18 on: May 28, 2011, 07:23:55 PM »
White 4 hole just like the 24 lb truck injectors.  Except the metal part is black not silver/chrome.
« Last Edit: May 28, 2011, 07:24:34 PM by grumpygy »
« Reply #19 on: May 28, 2011, 08:10:12 PM »
those are design II (4 hole disk design), not sure about the color - the white one in the FAQ is a pintle design (1 nozzle with needle) and that is different than what you are describing
you have the p/n stamped on the plastic portion of the injectors and is the one you posted?
« Reply #20 on: May 28, 2011, 08:23:42 PM »
No Nothing on the plastic portion, and it for sure is 4 hole.
« Reply #21 on: May 29, 2011, 06:16:57 PM »
Think when I get the fuel down a little father I will just drain it.  She runs great for a while then all of a sudden starts to sputter and miss.  Then back to running great.  Also from time to time real hard to start other times starts just as it starts turning.
« Reply #22 on: August 28, 2011, 11:18:17 PM »
Just to add a note.  It was the new Coil I put on.  Changed that and misfire went away.
« Reply #23 on: August 29, 2011, 04:26:06 PM »
For some reason, I go through coils like a kid goes through candy...  I guess the position of the coil does not help, as I plunge it into mud and water all the time.  I am considering relocating it higher up on the firewall or something.  Also, for some reason, the high end coils (Accel, PD Screaming Demon) tend to last less than the cheapo ones.
