Author Topic: Airbox Placement confusion  (Read 9704 times)
bammerman
Re: Airbox Placement confusion
« Reply #15 on: June 14, 2011, 09:56:10 AM »
Anyone got one of these for sale?  Or should I just buy an after market one?
« Last Edit: June 14, 2011, 10:49:13 AM by bammerman »
« Reply #16 on: June 20, 2011, 04:58:59 PM »
Let me check with my club. Maybe someone has one laying around.
« Reply #17 on: June 21, 2011, 09:16:21 AM »
So far a guy has just the airbox, not the tube from the airbox to the TB.
bammerman
« Reply #18 on: June 22, 2011, 01:32:55 PM »
Bummer, Here is a bad thing and maybe one of you can answer this.  Is there a part for this to mount too?  On my throttle body there are three holes but nothing to mount too.  just flat and three holes
« Reply #19 on: June 22, 2011, 04:59:57 PM »
there was a person here that did a cai for the tbi and just attached the tube to the plastic elbow where the normal corrugated tube would connect.  will try to find the post and provide the link...
edit. found it. page7 of this thread
http://4bangerjp.com/forums/index.php?topic=7650.90
« Last Edit: June 22, 2011, 05:57:54 PM by chardrc »
bammerman
« Reply #20 on: June 24, 2011, 12:27:08 PM »
Ok I got a air box to throttle body for the 02 and it won't work.
Here is what mine looks like, it has a weird  triangle shape and only fits on that way.  The 02 is round.
here is the bracket that had a hose attached that fits on my throttle body.  All the others I have seen do not look like this :(
it only goes on one way and its pointed the wrong way in my jeep - no room for airbox
« Last Edit: June 24, 2011, 12:27:50 PM by bammerman »
bammerman
« Reply #21 on: June 24, 2011, 12:35:59 PM »
This is what my throttle body looks like
« Reply #22 on: June 24, 2011, 12:46:18 PM »
Is that the side of the TB that faces up?
bammerman
« Reply #23 on: June 24, 2011, 12:51:06 PM »
Yeah that bracket and hose mounts to that
« Reply #24 on: June 24, 2011, 12:57:28 PM »
This is what mine looks like. The Tube just slips on top of the TB and you tighten the hose clamp thing.
Looks like a adapter would need to be made with a bit of a lip on it so the tube can slide on?
bammerman
« Reply #25 on: June 24, 2011, 01:02:30 PM »
There is a rubber hose that slips on that bracket and is mounted to that TB.  I can't cover that triangle piece up because there is something with the air sensor or something along those lines there.  You can see it in the tiny picture.  I am not sure why mine looks so different.  When I look up 88 cherokee I get a TB that looks like yours so maybe mine is older or something.  I did see a few like mine in the junk yard today, though in same year range
« Reply #26 on: June 24, 2011, 01:06:56 PM »
Maybe someone who knows more about the older stuff can answer. I don't know if there was a few styles of TB's for the pre-MPFI.
Sorry.
bammerman
« Reply #27 on: June 24, 2011, 01:08:22 PM »
I am thinking of taking the bracket to a metal shop and having them weld a pipe on there with the bend in it about 3 inches up to just get it to work for now and put together my own cold air intake.
bammerman
« Reply #28 on: June 24, 2011, 01:48:08 PM »
said screw it having a shop custom fit a 3" pipe on it and make my own cold air intake for it.
« Reply #29 on: June 24, 2011, 01:59:52 PM »
Has anybody noticed he is talking 4.0 not 2.5.  Also was not 1990 a Carbed engine.
