Author Topic: Airbox Placement confusion  (Read 9700 times)
bammerman
« on: May 25, 2011, 06:31:54 PM »
Hello guys,
been awhile since I have wrote here. Finally have my engine mounted the 88 4.0 and now we have no clue what to do with the airbox.  Just doesn't fit. Do I need to do a cold air intake, what have other people done with this issue.  I put power steering in it where it didn't have it before and took all the room.
bammerman
Re: Airbox Placement confusion
« Reply #1 on: May 25, 2011, 06:32:10 PM »
I would post a picture but upload folder is full
« Reply #2 on: May 25, 2011, 06:48:09 PM »
I picked up a 4.0 intake setup (stock) for free and put it on my YJ.
I had to drill 2 holes to attach it. Other than that fits like it was made to.
bammerman
« Reply #3 on: May 25, 2011, 06:56:59 PM »
I think that will work because that is where I would have to relocate mine too.  thanks man.
bammerman
« Reply #4 on: May 25, 2011, 06:58:58 PM »
Is it for a wrangler or a cherokee?  Can you give me details on the exact thing I would need to buy?
bammerman
« Reply #5 on: May 25, 2011, 07:01:23 PM »
Also how did you deal with the vacuum?
« Reply #6 on: May 25, 2011, 07:13:02 PM »
Pretty sure it's off a 02 TJ. I got everything from the airbox to the TB. It's just the air tube and the airbox really.Mine came with a pretty fresh filter too.  Make sure the clamps are still there.
Whaddya mean? Just make sure the hoses are all hooked up.
bammerman
« Reply #7 on: May 25, 2011, 07:26:07 PM »
My mechanic said the vacuum had to run into the airbox line so figured it was a special but or adapter
« Reply #8 on: May 25, 2011, 07:47:57 PM »
Look at mine in the above PIC. There is a line that comes off the valve cover and T's. One goes to the brake booster and one to the air tube. The air tube has a fitting molded in to it. I might have had to buy new tubing but I don't remember. The plastic T is a factory thing. It has always been on.
bammerman
« Reply #9 on: May 25, 2011, 08:14:49 PM »
Thanks again Scott Karma ++ bro, miss my wrangler haven't driven it in almost a year :(
« Reply #10 on: May 25, 2011, 09:15:10 PM »
Scott, if your booster is connected to the air filter tube and the valve cover is not working at all - there is no vacuum there. the booster should go to the intake manifold directly (no Ts or anything like that, so it get's max vacuum). I have no idea how you can stop that Jeep if it goes to the air box tube that goes to the t/b.
« Reply #11 on: May 25, 2011, 09:20:10 PM »
I think you're seeing the Evap canister line that connects to the T.  it normally goes to the airbox.
« Reply #12 on: May 25, 2011, 09:55:40 PM »
I am sure I am wrong on the brake booster line.  I forgot the evap can is in that corner under the brake booster. Next time I pop the hood I'll take a look.
« Reply #13 on: May 26, 2011, 09:02:47 AM »
The line going to the T sure looks like the Evap. line.  It's a hard plastic.
Brake booster goes to the manifold and is rather thick.
bammerman
« Reply #14 on: May 26, 2011, 07:41:17 PM »
All I know I am finally | | <- this close after a year of trying to rebuild my dead beast.  You all have helped a lot and I learned a lot from ya so thanks.  Guess I have to be another donator this year for the help :D
