Author Topic: Regearing curiosity  (Read 6414 times)
Offline Lu
Regearing curiosity
« on: May 26, 2011, 12:41:28 PM »
Quick question... I will be putting 33s on the rig soon and will most likely need to regear. My question is: is it imperative to regear both front and rear?  What would happen if i regeared only the rear?
I may not be able to get anywhere quickly, but I can get most anywhere I please.
Re: Regearing curiosity
« Reply #1 on: May 26, 2011, 12:51:32 PM »
You would not be able to shift into 4WD.
« Reply #2 on: May 26, 2011, 02:22:39 PM »
and if you do that you'd brake something in the drivetrain.
« Reply #3 on: May 26, 2011, 03:58:51 PM »
 :thumb:
« Reply #4 on: May 26, 2011, 04:17:34 PM »
Pretty sure the T- case would...
« Reply #5 on: May 26, 2011, 04:26:21 PM »
If anything was going to BREAK it would probably be a U-joint.  The front axle would drag the slower rear axle.
« Reply #6 on: May 26, 2011, 04:28:59 PM »
depends if your shifting on the fly or not lol
« Reply #7 on: May 26, 2011, 04:30:35 PM »
It could work if you put the 33s only on the rear axle and regeared just right.
« Reply #8 on: May 26, 2011, 04:50:03 PM »
That's what stadium trucks used to do.  Run 33's up front with 4.10's and 35's in the rears with 4.56's.
Some mud trucks run similar setups so the front floats more.
« Reply #9 on: May 26, 2011, 04:58:52 PM »
The front and rear outputs would spin at different speeds. The chain system is not set up for 2 speeds at once. Something would need to give.
Having 2 tire sizes to offset 2 gear ratio's works since it puts everything back to + or - a tolerable amount.
jcrockarell9937
« Reply #10 on: May 29, 2011, 04:17:36 PM »
just looking ahead at future plans...Is regearing worth it?(I mean I understand that performance will suck if you dont) Price? And does it eliminate 5th gear in a 5 speed manual?
« Reply #11 on: May 29, 2011, 08:52:10 PM »
Will it make a difference, yes.  Is it noticeable, yes. is it expensive, yes.  Is it worth it, yes.
« Reply #12 on: May 29, 2011, 11:27:37 PM »
Agreed! For a small underpowered motor gearing is a HUGE part of making it work right.
knotts89
« Reply #13 on: May 30, 2011, 02:38:29 AM »
I think its the only way to make it enjoyable to drive if you have 33s or bigger but that's just my opinion
« Reply #14 on: May 30, 2011, 09:27:12 AM »
I used to run 31's and 4.88, and it was almost like having a 4.0L.  When I switched to 33's, it went back to a 4-banger again...  I now wish I had gone with D44's front and rear so that I could go to 5.13's instead of 4.88!
