Author Topic: running problem  (Read 1195 times)
jinxjay
running problem
« on: May 26, 2011, 04:04:47 PM »
hi folks, I was wondering if anyone had any ideas on a problem of mine,
i've looked through the boards but cant find anyone with the same problem as me.
I have a 1989 wrangler with 2.5 tbi,
it starts fine cold, idles ok and drives for about 5 minutes, till the temp gets about !/4 of the way up,
then it starts cutting out, dropping rpm's then stalling and a flat spot a mile wide.
if you can nurse it through this for 3 to for minutes it just clears, and when up to temp runs perfect no stalling or any other issues,
has anybody got any ideas???
thanks in advance Jason.
Re: running problem
« Reply #1 on: May 26, 2011, 08:31:00 PM »
ECM temp sensor maybe? unless it's some fuel delivery issue. This is in case your problems are not just at idle but loss of power when driving as well.
