Author Topic: Looking for a throttle body spacer  (Read 3527 times)
Quite Happy
« on: May 26, 2011, 10:34:39 PM »
OK, most of what I've been reading tells me my next performance mod needs to be a throttle body spacer.  Trouble is, my 1985 CJ7 has a carburetor, not tbi.  I've searched all over looking for somebody, anybody, that makes a spacer for a single barrel carb.  It only has 2 bolts.  I tried Power Aid, but no dice, chico.  I suppose if I have to, I'll find a machine shop to make me one out of aluminum, but I don't want to have to refinance my house to add a few more horsepower to my ride.
Any ideas, folks?  Where can I find a spacer for my old timer?  Going fuel injection would be nice, but requires lots of money that my dearly beloved is loathe to allow me to spend.
Offline VA_YJ
  • Now I need a CJ...
Re: Looking for a throttle body spacer
« Reply #1 on: May 27, 2011, 09:16:18 AM »
Don't know of a spacer for your rig.  Many of the CJ owners convert to a Weber 2 barrel, but I can't find one for an '85.  These are generally less than $300.  You might find a used one for way less.
Another thing to consider is propane injection.  It costs a little more ($850), but it does well on steep terrain and you can hook a grill up to your tank!  The propane kit allows you to switch back and forth gas/propane.
http://www.gotpropane.com/p4.html
Another option is to find a wrecked 4 cyl Cherokee or Wrangler with MPFI (91 and up) and strip the whole system off for a transplant.  This is usually cheaper than the Howell system.
RT
« Reply #2 on: May 28, 2011, 11:36:58 AM »
You could make one yourself out of heat resistant plastic/composite from home depot or I even heard of people making carb-raisers out of wood. But having a shop professionally do it would probably be your best cheapest bet.
« Reply #3 on: May 28, 2011, 12:37:22 PM »
Actually think a carb change would be the way to go.
www.racetep.com/weber/INS-WK550-34.pdf
« Reply #4 on: May 28, 2011, 12:53:44 PM »
I think the best bang for the buck without spending too much might be a Weber Carb kit.
A MPFI conversion would give him the most HP (+20) and TQ increase but it's not going to be cheap, even if you're salvaging parts.  All the little things will add up fast.
« Last Edit: May 28, 2011, 12:54:11 PM by Jeffy »
« Reply #5 on: May 28, 2011, 12:54:15 PM »
Have not used the Jeep Kit but did put thisa kit on my MGB and was very happy with it.
http://www.jcwhitney.com/carburetor-conversion-kit/p2020672.jcwx?filterid=c2039d1168y1985j1
« Reply #6 on: May 28, 2011, 05:42:01 PM »
there could be piston, cyl head and cam differences as well, not sure though but i recall seeing a split in p/n by years and the carbed ones were different.
Quite Happy
« Reply #7 on: May 30, 2011, 08:54:13 PM »
Thanks for all the input, folks.  Since I just got back from Tucson, and it's Memorial Day, I'll have to make some phone calls in the next couple of days to see if the Weber is California emissions legal.  Otherwise I may be hitting some junkyards and accumulating what I need for MPFI.  In the meantime, I'm going to see what I can do about making my own spacer.  What do I have to lose?  If it doesn't work, I can always pull it off.  Always start with the cheapest and easiest method, right?  I like the propane idea, but that may be for down the road.
« Reply #8 on: May 30, 2011, 09:11:15 PM »
Oh CA emissions, huh?  That's gonna be a no-go.  Not because it won't pass emissions but because Weber doesn't bother to pay for a CARB license.
« Reply #9 on: May 30, 2011, 09:16:22 PM »
Less than a week after I moved out of Calif is when I put the Weber kit on my MGB.  Love not having to smog anything.
Quite Happy
« Reply #10 on: May 30, 2011, 09:20:23 PM »
Politics.  What would we do without it?   :brick:
« Reply #11 on: May 30, 2011, 10:05:28 PM »
It has more to do with money then politics.
« Reply #12 on: May 31, 2011, 03:45:21 PM »
:thumb:
