Author Topic: Alternator cables  (Read 9724 times)
  • 4BangerJP.comŪ Donator
Alternator cables
« on: May 30, 2011, 05:26:08 AM »
Bought one of these Load Boss alternators since a few more power draws are probably in the immediate future -- namely e-fan, some better head-lights (Cibies or IPFs), maybe an amp and another set of speakers...:
http://cgi.ebay.com/ebaymotors/91-98-JEEP-CHEROKEE-WRANGLER-HI-OUTPUT-ALTERNATOR-220-_W0QQcmdZViewItemQQhashZitem19b99694ddQQitemZ110487835869QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1392wt_1165
What about wiring though -- anybody using 4 gauge alternator power cable?
« Last Edit: May 30, 2011, 05:30:03 AM by chrisfranklin »
Re: Alternator cables
« Reply #1 on: May 30, 2011, 08:05:09 AM »
you'll most likely need a cable from the alternator straight to the battery, stock wiring is only good for up to 100 amps (2 x 50amp fuses into the PDC)
« Reply #2 on: May 30, 2011, 11:19:31 AM »
Ordered the Load Boss 4 gauge power cable they advertised.  Thanks for the clarification, Sharp.  :beers:
« Reply #3 on: May 30, 2011, 11:30:22 AM »
Had not thought about this, just put on a 160 Amp.  Getting ready for the  electric fan.  just have to pick up ends cause I have plenty of cable on hand.
« Reply #4 on: May 30, 2011, 11:47:26 AM »
I have their 164A (or so; dont remember exactly the amperage), and used their cable from the alternator directly to the battery IN ADDITION to the stock cable.  I have abused it frequently (taking it for mud baths, submerging it in water, and using all the electrical gizmos like Ford/Linconln eFan, 4 Aux lights, GPS, CB, 2m radio, charging phone, stereo, and enything else I can think of, and so far, so good.  Not a single issue have I had with this alternator in over 3 years that's been in the Jeep...
« Reply #5 on: May 30, 2011, 11:58:49 AM »
That wiring will take up to a max of 135a if it's really 4 gauge.  You would probably want to put a fuse or CB on that line though.
« Reply #6 on: May 30, 2011, 12:14:46 PM »
Is it better in the long run to do the 2 gauge they are selling?
« Reply #7 on: May 30, 2011, 12:17:16 PM »
Not unless you're planning on bypassing the PD box.  2 gauge is rated for 185A.  Also, you run into the problem of getting the cable to  to connect to the alternators small terminals.  I'd just run the 4 gauge so you have a 235A limit.
« Last Edit: May 30, 2011, 12:18:19 PM by Jeffy »
« Reply #8 on: May 30, 2011, 12:31:01 PM »
OK, thanks Jeffy.   :beers:
« Reply #9 on: May 30, 2011, 12:47:28 PM »
But if you run it in addition to the stocker, you should have at least 185A, and I doubt he'll use much more than that...
« Reply #10 on: May 30, 2011, 01:16:23 PM »
Gotta catch up...  read the other post afterwards.
« Reply #11 on: June 17, 2011, 01:01:12 AM »
Got the Load Boss alternator.  Decal on it says 220amps.  Whatever I have on there now is oem and is either the original or perhaps a replacement I installed about a decade ago (not for sure on this).
road2damascus
« Reply #12 on: June 20, 2011, 09:01:46 AM »
I run a universal starter cable from NAPA on my 160amp alt to battery. I also have a 220amp alt on my Jimmy with the same starter cable. I am not sure what the gauge is but it is thick.
« Reply #13 on: June 20, 2011, 09:09:18 AM »
Most common are 2# and 4# but I suspect it's 2#. 2# is good for 181A.
« Reply #14 on: July 16, 2011, 01:11:10 AM »
Felipe, so you are saying you have 2 cables mounted to the insulated bracket on the alternator -- 1 that is the original going directly to the fuse box and out of that to the battery and 1 (say 4 gauge) that runs straight to the battery and has a fuse  added?
If that's working, that's probably the way I'd go.  Don't have the greatest logistics setup for messing with wiring through the PD box (finding myself doing all this on the street, at night, with my place and extra tools miles away)
What sized fuse do you have on the wire running from your 164 alternator to the battery?
