Author Topic: Dyno boost performance chip  (Read 1690 times)
JeepNeek
« on: June 08, 2011, 01:36:46 AM »
I tried searching existing topics don't think any one has mentioned this chip anywhere.
So yesterday I came across this chip ??? which supposedly helps with HP
Desccription Says
"Dyno-BOOST is a fully adjustable performance fuel controller designed for fuel injected vehicles. It tricks signals being read by the ECU, resulting an adjustment to the fuel curve, which is what causes the increase in HP, as well as improves acceleration and throttle response within the entire RPM range, simply wires inline with factory IAT (Intake Air Temperature) or MAF (Mass Air Flow) sensor and plugs into the O2 sensor harness. Crisp acceleration, much more horsepower and torque, lower quarter mile times and fine throttle response. Installation is easy, no special tools or expertise required. Gain +15-50 additional HP, and extremely dynamic acceleration by up to 30 %. This mod will not affect engine reliability or endurance. Dyno-BOOST tricks the ECU thinking the intake air much more cooler, then the ECU will send more fuel for a richer mix besides it blocks restrictions generated by the ECU."
http://us.ebid.net/for-sale/dyno-boost-performance-chip-jeep-wrangler-2-4l-17409842.htm#desc
The science behind it seems simple and logical. :eek:
Thoughts
Re: Dyno boost performance chip
« Reply #1 on: June 08, 2011, 08:36:18 AM »
http://4bangerjp.com/forums/index.php/topic,7280.msg53798.html#msg53798
http://4bangerjp.com/forums/index.php/topic,9609.msg82496.html#msg82496
EDIT
you gotta love this
the extent they go to convince you of the validity of their product - 2 blue wires that do absolutely nothing, they are not hooked anywhere inside that "chip"
« Last Edit: June 08, 2011, 08:44:56 AM by sharpxmen »
