Author Topic: AC Wire  (Read 1977 times)
Offline mrcabinet
AC Wire
« on: June 14, 2011, 05:34:51 PM »
Now that the hot weather is here, I'm finally getting around to completing the flex-a-lite install I started last fall. It is complete except for the AC trigger wire. It says to hook it up to the positive side of the AC clutch circuit. Can someone point out where that is one the PDC?
Thanks!
Re: AC Wire
« Reply #1 on: June 14, 2011, 10:16:53 PM »
what year is it? (can't remember, if it's a '95 i can look it up in the FSM, otherwise i don't know)
you could also trace the color of the wire though, in case you can't find an answer here.
Re: AC Wire
« Reply #2 on: June 15, 2011, 11:34:17 AM »
On my '94 it was a blue wire running along the firewall on the main wire loom...
Offline mrcabinet
Re: AC Wire
« Reply #3 on: June 16, 2011, 01:20:37 PM »
2001 TJ
Re: AC Wire
« Reply #4 on: June 16, 2011, 01:24:40 PM »
2001 TJ
sorry, can't help.
Morris4x4 has online FSMs, you might want to see if you can find it there.
