4BangerJP.com
September 08, 2010, 06:52:12 AM *
Did you miss your activation email?
News: Read the FAQ.                                      ...Everybody's Doing It!                                  ...Except you!
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Banks Header  (Read 268 times)
aparke4
Newbie
Offline Offline
« on: July 25, 2010, 09:06:50 PM »
After much research, the overall conclusion seems to point out that the header component on the 4 banger yields little benefit. After going with a bored tb, air intake, magnaflow hi flow cat and turbo muffler I figured to round out all the add ons the banks header was the answer. I have already been so impressed by the additions so I decided to buy another banks header (already have one on the xj and love it! 4.0 btw).
The header costs roughly the same - about 350. The little guy is built like its bigger brothers: 1/2 flange, mandrel bent tubing and double tig welded throughout the whole piece and stainless tubes I believe. An added benefit is that it weighs considerably less than it stock counterpart: I would say a good 10-12 lbs less. The stock cast unit is almost like a boat anchor compared to the banks. Anyways having done this on a 6 cyl even though I vowed NEVER TO DO ONE AGAIN!! (can't you tell how much i love installing headers?!) I figured more space and 2 less cylinders would make it ok. Luckily my motor is like new with 8k on it (140k on body) - a very clean 01 TJ with zero rust. I hit everything with PB blaster just to be safe two days prior to install.
About 3 hours later taking my time with a buddy we were done! I have done this before which helped throughout the install we were chilling, drinking cold adult beverages and cruising really through the install. The only slip up was the donut: first round of tightening the downpipe up the donut did not sit right causing a exhaust leak. A little rearranging and we were good. My manifold gasket even looked brand new - oh ya it is. Anyways straight forward install. Here are my 4 cyl notes post install:
PB blast every bolt prior!
Do not forget about the two bolts under manifold: by taking off power steering pump, belt and some assorted wires you CAN get to these bolts. A good swivel socket is a must. Make sure you tighten them snug and be patient: they can be hard to get to.
Graphite greased lithium whatever donut will smoke and smell for a couple minutes while motor warms up. This is normal: keep hood open and I like to have a fan handy to blow it out of your work area.
Nothing was metric that I can remeber: 1/2 and 9/16 mostly on the hardware. My bolts looked good and reinstalled them with anti seize (same on xj with 100k) but some people do replace bolts for piece of mind. Just do a good inspection while they are out.
Always disconnect neg. side of batery so the computer can relearn fuel curve.
Manifold has two studs it sits on which is a good benchmark/ visual for reinstall of gasket and manifold.
Impressions:
A little more throatier exhaust tone.
1k - 3k RPMS seem to rip through smoother and faster.
Idle is crisp and smooth - great with hi flow cat and exhasut system at idle.
4th gear and 5th gear - most improvement on top end! I can hold 4th longer before shifting and 5th seems to use less rpms at highway speeds of 65-70.
Little more pep in throttle.
MPG - will report back.
Overall thoughts:
Fit: 5/5
Performance: I think banks headers are the best: but 4 cyl benefiting from almost 400 dollar product? Maybe a couple horses and torque points: 4/5
Cost: 2/5 - pricey
I really love the way my TJ drives but it has taken doing a lot to the motor. the banks header is not needed but if you really love your 4 cylinder or have the cash laying around it go for it. To be honest, i think I would have rather bought a set of aussie lockers. I really do like it though and now have a complete full exhaust on my TJ.
Not a great bang for the buck but banks deliverers a bad ass header and will help any 4 banger out there.
Logged
1995yj
Member
Offline Offline
WWW
« Reply #1 on: July 25, 2010, 09:24:07 PM »
Nice write up, +1  thumbsup
Logged
[95 YJ: 2.5, AX5, STK 4.11 Gears, 4.0 TJ TB, 31x10.5's BFG MT KM2, 4" Pro Comp Lift, Electric Radiator Fan, Banks Monster Cat-Back, incrediable shrinking wallet Huh?]
97 TJ - I dont wave
Member
Offline Offline
Cracked 5 banks header - Same spots every time -
« Reply #2 on: August 03, 2010, 08:19:40 PM »
http://4bangerjp.com/forums/index.php/topic,3678.0.html
Check out this read before you buy Banks.
Logged
97 TJ 4' lft; 1' body; Bilstn shcks; stainles break lines; 35x12.5 procmp xmudterrain; AdvncAdpter SYE; TOM WD's Drive shft; 1' mtr mount lift; 33 Engnerng high skid plat; Magna Flw mufler & Cat.; Banks Heder; K&N fltr; Flow Kooler wtr pmp; 4.88's ARB's; Rhno lined; Ford Injctrs; Jet chip;RockJock60
aparke4
Newbie
Offline Offline
« Reply #3 on: August 04, 2010, 05:28:17 PM »
so your the banks header guy! I read a lot of your problems and it sounds like you might just have bad luck. I have had a banks header on my xj for 4 years now going strong. The TJ motor mounts look good and I am putting a flex pipe on it. I will report back in a couple months if there is any mishaps.
Logged
97 TJ - I dont wave
Member
Offline Offline
« Reply #4 on: August 05, 2010, 07:04:55 PM »
oh
Logged
Torch_Ind
4BangerJP.comŽ Donator
Member
Offline Offline
« Reply #5 on: August 06, 2010, 11:55:40 AM »
that runs the stock down pipe?
My pacesetter header, looks much longer tubes and comes with new down-pipe making it i think 2 inch right in to the cat.  was also cheaper the a Banks.
power wise I don't know if it helped other then sound cause I put in a fresh eng when I installed it and also got a 64mm tb and port matched the intake to the tb and to the head. so with that combo it made quite a bit of difference doing the combo.
« Last Edit: August 06, 2010, 12:13:15 PM by Torch_Ind » Logged
Jeffy
#1 FanŽ
Member
Offline Offline
« Reply #6 on: August 06, 2010, 01:09:21 PM »
Don't forget they are also made out of rust.   lol  I like the Pacesetter's design with the long torque tubes but their choice of material could have been better.
I still haven't heard some anyone with a Borla having cracking issues.  confused
Logged
Torch_Ind
Member
Offline Offline
« Reply #7 on: August 06, 2010, 10:08:27 PM »
I have had mine about 2 years now with no problems. and I live in high salt for winter conditions !!!!
Logged
ORILEY
Newbie
Offline Offline
« Reply #8 on: August 10, 2010, 03:03:41 PM »
 I've had mine on for only a short time now, but have without a doubt felt a definite performance gain. The best benefit being the extra torque/power needed for some of my daily hill climbs on my daily  80 commute to work thru the many hills in my area.(lets face it every bit helps).
Logged
Torch_Ind
Member
Offline Offline
« Reply #9 on: August 10, 2010, 04:48:50 PM »
the banks or pacesetter
Logged
Pages: [1]   Go Up
  Print
Jump to:
SMF Theme © Gaia
Valid XHTML 1.0! Valid CSS!
