		General Forums => The Mess Hall => Topic started by: FourbangerYJ on March 30, 2009, 10:08:45 AM
				Well, the Dipstick thread got me thinking about air filters.
I am running a K&N with a pre-filter on a Rock-it City air tube.
So what are you running?
				Fram or Oreily house brand - stock type.  Used to run a K&N cone on a tube but it was noisy and I kept clogging it due to the dust sticking to the oiled media.
				Used to run a Conical K&N but it got dirty fast and allowed dirt into the tube.  After that it was Fram paper media and the stock box.  Now  it's the stock box with a Fram Air Hog.
				Stock type paper, usually Fram. Too much dust for anything else.
				I think I found a 4.0 TJ air tube and box. If I get it I'll try and swap it in.
Thanks for the idea Chuck!  :thumbsup:
				stock box with cheapo filter that it came with
My deal fell thru. But I am going to keep an eye out.
That's exactly what I'll have in the next couple weeks. Right now it's just the stock junk with the restrictors removed and a K&N drop in.
				i run a kn conical but im not in alotta dust unless im at the trails and for that matter it hardly ever leaves my house except for trail rides/  so i just oil it good and clean it when i get home/  i need as much air as i can get in my motor to keep the high rpms screaming on the trails for so skinny pedal fun in the dirt
				stock box and filter replacement... I removed restricters and drilled holes in box on side nearest fender.. dont know if its right but thats what i did
				K&N  with No Box  :smokes:
				What ever is cheap. So yea usally a fram.
				im running AEM brute intake-i like it-just about the only engine mod i sorta noticed a difference from.
Does removing restrictors make that much of a difference?
The restrictor everyone talks about is the turn down and the venturi on a YJ.
http://4bangerjp.com/forums/index.php/topic,3595.0.html
				bout the most noticeable mod I have done was the tb swap.
				I'm using an AEM Brute Intake on my truck and will be switching the jeep over to one also as soon as I get the current projects on it done.  It does alot better job filtering then a K&N and I like that you don't have to oil the filter, which just helps attract more dust to it.
the hole point of an air filter is to filter out dust and other airborn crap.. so i don't see why people compail about oil attracting dust to air filters when thats their job.. and it doesn't attrack the dirt it just makes it stick... not saying k&n is better but just throwing out my observation...
im def happy with mine. i dont think too many ppl on this forum run that intake but it def is worh it in my opinion. i got more of a result from that intake then i did when i put in the 62mm TB-hardly felt a thing with that on-though i guess it grunts and gives me a bit more oomph but nowhere near the results others are posting about it-guess myTJ is destined to be a slow, low HP, gas sucking (13mpg on 31s baby!), pig lol. I used to suck down half a tank on a 60 mile trip to NYC-highway!!-put in the AEM, drank just a quarter of a tank. put in the TB and mpg went down a hair but no where near suckin half a tank on a 60 mile trip.....so i def think AEM is a good filter
Problem is that so much dust sticks to a K&N that your motor stops running.  That and the K&N lets some of that junk through.  Their better performance is usually because they don't filter as well as a stock element.
				One of the diesel magazines I read, can't remember which one, but a while back did a comparison of the filters and the K&N was one of the worst at actually filtering stuff out.   Yeah it lets in a lot more air, but its not blocking anything from the filter.  I noticed that when I was washing out my AEM filter the other day that when it started filling up with water, the filter actually started filling up with water, where the K&N filter emptied the water out as quickly as it went in.  Which this kind of helps lead me to believe that it doesnt filter as well
				well a couple of things,  just my two cents,  kn filters are designed to work with oil and most people mess that part up/  oil bath filters have been around for ever and always worked/  two i run a prefilter on my kn (just like most of the old oil bath filters had)/  the only thing i can say about the aem 4cyl intake was that i sent mine back/  its fitment was terrible/  the metal surround was not shaped well for the cavity and multiple things had to be relocated to make it fit/  the worst for me was the the couplers did not seat far onto the pipes (meaning the pipes went into the couplers very shallow) and that made me think there was a good chance of them coming apart,  cause i have had it happen before,  so in not so many words,  i was displeased with the aem and sent it back where it came from
				I remember reading a JP article years ago that did a dyno for each of the different kinds of set ups and the stock airbox with a good clean filter (they recommended Mopar) performed as well as the high dollar set ups.  fwiw, ymmv
