Author Topic: Leaf spring bushings  (Read 2459 times)
« on: June 23, 2011, 06:07:10 PM »
I noticed one of my spring bushings that hold the shackle to the mount is cracked. Not on the spring end of the shackle but the top. Anyway, what do you like the rubber ones or the aftermarket stuff such as Energy Suspension?
Re: Leaf spring bushings
« Reply #1 on: June 23, 2011, 06:10:51 PM »
Just changed all mine to the Energy Suspension stuff.  Good so far.
« Reply #2 on: June 23, 2011, 06:43:34 PM »
Rubber ones flex better.  I've always used Poly though.
« Reply #3 on: June 23, 2011, 06:57:15 PM »
I'll prolly call Deaver tomorrow and see what they have on hand. I know they sell stuff individual VS. buying a whole set.
I have noticed a squeek type noise coming from that corner. I grease the snot out of those things. Not sure if that is the reason or not.
« Reply #4 on: June 23, 2011, 07:05:45 PM »
You'll usually get a knock if the bushing needs to be replaced.
« Reply #5 on: June 23, 2011, 08:26:13 PM »
HHmmm. Don't recall a knock. Might be those Baja Bushings. They have nylon bushings and you can't lube them unless you take everything apart.
I can see the tear in the shoulder of the bushing, so I know it's shot. In theory I could leave it for a while, but I don't like to do that.
« Reply #6 on: June 24, 2011, 09:55:17 AM »
The ones Deaver sells are urethane. http://www.deaverspring.com/products/bushings.html
It's nice they have them in bulk so you don't need to buy the whole set if you don't need to. Should be here on Monday.
