Author Topic: fuel filter swap  (Read 37496 times)
bammerman
Re: fuel filter swap
« Reply #30 on: June 28, 2011, 09:47:28 PM »
I am running VERY lean by what mech said.  That is why I am about to say screw it and just get a 4.0 tank and pump if they fit in a YJ.  I am way too confused currently on what to do with my YJ tank needing a pump replacement with the XJ 88 engine.
« Reply #31 on: June 29, 2011, 12:42:23 PM »
I'll elaborate here since someone else might be interested as well.  You remove the stock pump completely.  Then you will need to extend the lines in the tank and extend the pickup line down and add a screen/filter.  The mount an aftermarket fuel pump to the frame or cross-member near the tank.
Another option would be to buy a MPFI sending unit but really you'll be spending about the same for either.  The advantage of the former is that if it ever goes bad you don't have to drop the tank.
bammerman
« Reply #32 on: June 29, 2011, 02:46:36 PM »
hate to keep asking but do you have a part number :D
Haven't other people done 2.5 to 4.0 swaps?  I am sure someone ran into this problem.
bammerman
« Reply #33 on: June 29, 2011, 02:54:25 PM »
http://www.jeepaholics.com/tech/25to40/25to40.htm
This gave me some guidance.  guess I can swap out tank and fuel pump, or try to make out what jeffy is saying :D
bammerman
« Reply #34 on: June 29, 2011, 04:14:40 PM »
http://www.jeepforum.com/forum/f12/4-0-conversion-83898/
6 or 7 lines down. Is this what you are talking about Jeffy?
3) The 89 and 90 YJ had return fuel lines already so I just installed an inline fuel filter and pump.
Is this what you are talking about jeffy?
http://www.quadratec.com/products/55107_99.htm  - it is a 4.2 fuel sending unit.
Or maybe this is more what I need http://www.hesco.us/shop.asp?action=details&inventoryID=43049&catId=7902
« Last Edit: June 29, 2011, 04:35:39 PM by bammerman »
« Reply #35 on: June 29, 2011, 08:33:06 PM »
if i recall correctly the mpfi fuel pump may fit in the tbi sending unit (was looking to see if the tbi pump fits in the mpfi unit and the answer was no becasue the tbi pump was bigger in diameter) so reverse engineering that the mpfi pump may fit the tbi sending unit. but doing an inline pump like jeffy said would be easier..
bammerman
« Reply #36 on: June 29, 2011, 08:47:11 PM »
Well I do not know how to do that :(
but on another note will this fit a 90 YJ
http://denver.craigslist.org/pts/2451822745.html
« Reply #37 on: June 29, 2011, 10:19:21 PM »
based on that picture you posted i think you already have the thick rad, so most likely your problem is the mixture - if you fix that you might not need to swap the rad (especially if it's thick).
why don't you measure the core, just stick a toothpick thru the fins and stop when it come out on the other side, keep your finger flush and pull the stick and measure. Or use the visual reference Jeffy mentioned (how much of the tank is covered by the core).
« Reply #38 on: June 29, 2011, 10:48:24 PM »
No get one that's for a YJ not a CJ.  Stop mixing and matching if you don't want to run into problems.
bammerman
« Reply #39 on: June 30, 2011, 12:50:11 PM »
I was just following what that one guy did.
Anyone in Denver or by highlands ranch that wants to make some extra cash and help a brother out?
« Last Edit: June 30, 2011, 12:50:31 PM by bammerman »
« Reply #40 on: June 30, 2011, 06:13:27 PM »
Again what year was the 4.0 from.
Seems the one you are trying to copy is a  98 XJ engine
« Reply #41 on: June 30, 2011, 06:16:38 PM »
His is pre-1991.  So it's Renix MPFI and not High-Output.
bammerman
« Reply #42 on: June 30, 2011, 06:24:41 PM »
I measured the radiator.  From when I feel it prick my finger then I marked the other side it is 1 1/4 in thick
« Reply #43 on: June 30, 2011, 07:51:54 PM »
What I'm trying to say is the link he posted about where he is getting his info is for a later engine not the one he has.
« Reply #44 on: June 30, 2011, 11:53:49 PM »
so you have the thick one, i don't think you need to change it unless it's clogged. fix the pump issue first and go from there.
