Author Topic: "new" Isuzu 2.5l diesel on ebay  (Read 3796 times)
RoadIslander
« on: July 19, 2011, 01:40:37 AM »
Came across this on ebay and thought it might draw some attention here.  Its a pretty penny, but..  sure would be sweet in a jeep
http://cgi.ebay.com/ebaymotors/Isuzu-4JA1-2-5L-non-turbo-diesel-engine-YJ-TJ-CJ-FJ-S10-_W0QQcmdZViewItemQQhashZitem4aacf9d548QQitemZ320729634120QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Re: "new" Isuzu 2.5l diesel on ebay
« Reply #1 on: July 19, 2011, 08:19:16 AM »
How legal would it be to get one of these? I noticed it's from Canada. Wonder if it would be a pain to get it imported and DOT legal in non-california states.
« Reply #2 on: July 19, 2011, 10:07:44 AM »
Technically it wouldn't be.  Really it would depend on your install though.  I know some DMV's will sign off on Diesels with little affair while others will send you to a referee station.  It's all on the digressions of the person inspecting it.
jramey
« Reply #3 on: July 19, 2011, 03:45:34 PM »
Now that would be sweet
« Reply #4 on: July 19, 2011, 05:14:32 PM »
What the guy doesn't tell you is that the engine has something like 76hp and 174lbs-ft  So I don't know why this guy think it would be a great swap in a Jeep.  The VW diesel is smaller and makes a lot more power stock and with a reflash, makes a hell of a lot more.
« Reply #5 on: July 19, 2011, 05:20:17 PM »
how do you mate it to the ax-5? 15?  or do you need adaptors?
« Reply #6 on: July 19, 2011, 05:54:00 PM »
it has mechanical injection, that's an advantage imo for simplicity, you only need 2 wires to get it working, the fuel valve and the starter solenoid. The vw has a lot better injection system but it is computer controlled so lot more complicated to get it going/working in a Jeep. it has plenty of torque but like you say less power by quite a bit (and that's b/c of the low top rpm mostly), so hwy speed might suffer but offroad would probably be great.
I remember reading about an isuzu swap at some point, it requires an adapter plate for AX15 or similar and some clutch disk to work with the existing flywheel/pressure plate. also from the video it seems that the starter is located on the driver side of the engine, that would/might need to be also relocated or something to be modified on the bellhousing to provide clearance if needed (could be as simple as cutting and welding or bolting on a piece of aluminum for protection if there are no structural issues on the bellhousing in that spot).
« Reply #7 on: July 19, 2011, 06:09:48 PM »
The most common Isuzu swap is the 4BD-1(2)T 3.9L turbo diesel which is comparable with the Cummin 4BT.  121HP (134HP) 250 ft-lbs.
BTW, the VW 1.9L was also offered with mechanical injection in the 90's.
jramey
« Reply #8 on: July 20, 2011, 03:47:32 PM »
Would the vw1.9 be a pretty simple swap if you had an adapter plate
« Reply #9 on: July 25, 2011, 09:37:20 PM »
There are adapters.  There have been adapters for a while actually.  Toyota's have been doing the swap for more then a decade.  You can buy a kit from a shop in Canada as well.  They also have a reflash available for the newer engines.  it's been debated in the Diesel Thread.
