Author Topic: Sierra Gear Cut-to-Fit Axle Shafts  (Read 1406 times)
« on: July 19, 2011, 11:39:01 AM »
http://www.sierragear.com/2011/07/sierra-gear-cut-to-fit-axle-shafts-2/
Do you have a custom width or hard to find axle housing? Sierra Gear and Axle offers universal cut-to-fit axle shafts for multiple applications including 9” Ford, Dana 44, Dana 60 and 8.75” Chrysler. These are available for both stock and custom spline applications, and feature stock replacement or chromoly material.  Sierra Gear’s cut-to-fit axles feature longer splines, up to 11” so the axle can be measured and cut-to-fit most stock and narrowed rear ends.  These versatile axles are also multi-drilled for different bolt patterns.  With the correct housing ends, these axles can be used for a wide variety of custom or stock differentials.
Call Sierra Gear at 800-359-4737 for more information or to find a distributor near you.
Application Info:
Axle Type    Part Number    Splines    Bolt Pattern    Full Length    Min. Length    Notes
Dana 44    SA D44-CL-30    30    5×4.5    32″    23″    Rear D 44
Dana 44    SA D44-DL-35    35    5×4.5/5/5.5    34″    24″    Rear D 44
Dana 60    SA 6033530    30    8×3.96    33.5″    29.5″    Full Float
Dana 60    SA 6033530C    30    8×3.96    33.5″    29.5″    Full Float
Dana 60    SA 6033535    35    8×3.96    33.5″    29.5″    Full Float
Dana 60    SA 6033535C    35    8×3.96    33.5″    29.5″    Full Float
Dana 60    SA 6036530    30    8×3.96    36.5″    32.5″    Full Float
Dana 60    SA 6036530C    30    8×3.96    36.5″    32.5″    Full Float
Dana 60    SA 6036535    35    8×3.96    36.5″    32.5″    Full Float
Dana 60    SA 6036535C    35    8×3.96    36.5″    32.5″    Full Float
Dana 60    SA 6039530    30    8×3.96    39.5″    35.5″    Full Float
Dana 60    SA 6039535    35    8×3.96    39.5″    35.5″    Full Float
Dana 60    SA 6039535C    35    8×3.96    39.5″    35.5″    Full Float
Dana 60    SA 6043535C    35    8×3.96    43.5″    39.5″    Full Float
8.75 Chrysler    SA 875001    30    5X4.5    31″    28″
8.75 Chrysler    SA 875002    35    5X4.5    30.56″    27″
Ford 9″    SA 900002    28    5X4.5/4.75/5    33″    23″    Small Brg.
Ford 9″    SA 900003    31    5X4.5/4.75/5    33″    23″    Small Brg.
Ford 9″    SA 900006    28    5X4.5/4.75/5    31.75″    25″    A20 Brg.
Ford 9″    SA 900006S    28    5X4.5/4.75/5    29.75″    21″    A20 Brg.
Ford 9″    SA 900008    31    5X4.5/4.75/5    31.75″    25″    A20 Brg.
Ford 9″    SA 900008S    31    5X4.5/4.75/5    29.75″    21″    A20 Brg.
Re: Sierra Gear Cut-to-Fit Axle Shafts
« Reply #1 on: July 19, 2011, 12:33:46 PM »
Sounds good.  Although my rear D44 (seems most likely out of a Plymouth Volare) is the same width as a stock YJ axle, I have no idea if the shafts are the same (the pinion does not line up exactly with the transfer case output), so this might save some trouble if I have to buy shafts some day.
