Author Topic: Spotlight Wiring -some pics inside too :)  (Read 2155 times)
mrdeath2000
« on: July 31, 2011, 08:37:18 PM »
Just installed my spotlights this weekend and finished my underhood ammo can(need to cleanup the can and paint it though).  What's a good source for power?  I was going to use an inline fuse and tie into where the fuse block is.  Reccommendations?
Also, CrownRoyal bags work great for light covers ;)
Thx, enjoy the pix.
Re: Spotlight Wiring -some pics inside too :)
« Reply #1 on: July 31, 2011, 08:49:57 PM »
Well, I'd highly recommend sealing the holes you made in the windshield frame.  That area is prone to rusting out.
For wiring, build a new harness and have the power directly from the battery.
mrdeath2000
« Reply #2 on: July 31, 2011, 11:05:58 PM »
Yea, I plan on throwing some silicone over/around the holes.  Also, I used threaded inserts instead of the sheetmetal screws.
For the wiring, what kind of harness do you mean?  I'm no expert on this.  You mean like wire a post block coming off the battery and tie into that?
I was going to check my fuse block to see if there is an open slot with power when the ignition is on/accessory.
« Reply #3 on: August 01, 2011, 12:13:18 AM »
You want to make a proper harness with a fuse as well as a relay and a switch.  You don't want to be powering a spotlight off the stock fuse box.
« Reply #4 on: August 01, 2011, 10:36:11 AM »
Looks good.  Not many Jeepers install this type of light but it will be good to be able to point the light different directions.
« Reply #5 on: August 01, 2011, 02:05:20 PM »
 :thumb:
