Author Topic: Mopar AC clutch  (Read 4650 times)
Mopar AC clutch
« on: August 06, 2011, 09:55:23 AM »
Does anyone know if you can get JUST the clutch assembly for the Mopar AC compressor unit?  Mine seems to have lived it's useful life, so I need a new one, but in Panama I can only get the whole compressor, not just the clutch.  Any ideas where to get it?
Re: Mopar AC clutch
« Reply #1 on: August 06, 2011, 10:08:09 AM »
Re: Mopar AC clutch
« Reply #2 on: August 06, 2011, 10:56:11 AM »
might work from other models (i'm fairly sure it will), try the junkyard, can't remember the name but they're all manufactured by a couple of companies (the compressors) so the clutches and coil are most likely interchangable for the same brand as long as the diameter of the pulley is the same.
Re: Mopar AC clutch
« Reply #3 on: August 06, 2011, 12:51:11 PM »
All you need s a Serpentine 6 or 7 groove clutch off a Sanden compressor.  Fairly universal.  Otherwise a clutch assembly will probably cost around $80-90 for the whole thing.  You can replace the bearings on them without having to but a completely new unit though.  Or is the magneto bad?
Re: Mopar AC clutch
« Reply #4 on: August 06, 2011, 04:29:39 PM »
Not sure; my dad is the one taking care of this in Panama...  Can't send him to a Junkyard, though, so that's out.
Re: Mopar AC clutch
« Reply #5 on: August 06, 2011, 05:09:10 PM »
Well if the bearing is bad it shouldn't make noise if the AC is on.  If the clutch is spinning and not engaging the compressor then the magneto is bad.
Re: Mopar AC clutch
« Reply #6 on: August 06, 2011, 07:46:09 PM »
OK, I see the outer part spinning, but the inner part will not.  If I tap it, the inner part will start spinning.  According to the AC place my dad took it to, they told him it was the clutch, but they did not know where to buy JUST the clutch, and the whole compressor was around $400.
Re: Mopar AC clutch
« Reply #7 on: August 06, 2011, 07:55:01 PM »
You can buy a whole compressor plus clutch (reman.) for under $200.  if it'a just the magneto then really that's all you need.  Problem is they don't sell them that way.  You'll need the magneto and the pulley.  A place specializing in AC units would probably have them.  Otherwise, you'll have to order one.
Re: Mopar AC clutch
« Reply #8 on: August 06, 2011, 07:56:21 PM »
Any recommended places to get the compressors you mentioned?  Keep in mind I still need to ship it to Panama...
Re: Mopar AC clutch
« Reply #9 on: August 06, 2011, 08:02:30 PM »
I'd try, http://www.nostalgicairparts.com/ or http://www.ackits.com/.  Those are the two big ones that sell online.  They should be able to set you up with a new clutch or a clutch and compressor.  Although I'd jsut replace the clutch.
Re: Mopar AC clutch
« Reply #10 on: August 06, 2011, 09:04:32 PM »
if you tap it and engages is most likely what Jeffy said - the solenoid/coil - you mean to tell me you would not be able to find a wrecked vehicle with an a/c on it in Panama? You could order it from the US but would cost you more than it's worth. Another thought would be that the wire at the solenoid is busted where it exits the metal shell, try to move the wire instead of tapping on it and see if it starts, if it does then you could carefully dig around the resin there and solder the wire, after that some cold weld or resin would seal it for good and you could have another 100k miles before it goes bad again - have a look, it's worth the time.
Re: Mopar AC clutch
« Reply #11 on: August 07, 2011, 01:02:24 PM »
I could...  But I am in Costa Rica.  My dad is the one in Panama, and, although I'm sure he loves me very much, I doubt I can get him to visit a junkyard...
I'll have him check this...
Re: Mopar AC clutch
« Reply #12 on: August 07, 2011, 02:02:56 PM »
There really isn't much to the magneto.  It's just an electromagnet.  The coils inside are set in resin so you can't do much to it.  There should be one cable that goes into that.  That's the only possible faulty link that could easily get damaged.  You might also want to check the connector to make sure it's not lose or the wires aren't frayed going into it.
Re: Mopar AC clutch
« Reply #13 on: August 07, 2011, 03:02:09 PM »
Well, according to the shop, it's the clutch, so I'll focus on trying to find one of those from the sites Jeffy posted...
Re: Mopar AC clutch
« Reply #14 on: August 07, 2011, 03:10:03 PM »
The clutch is the magneto.  The outer pulley comes off and can be reused.  If you're smacking it and it then works then it's more then likely the wire outside the magneto.
