Author Topic: Power Steering Reservoir after Electric Fan Install  (Read 4179 times)
tinkerab@gmail.com
« on: August 10, 2011, 08:36:24 PM »
I have searched the forums up and down and have not found a suitable option.  What is the best option for your power steering reservoir after you install an electric fan in a 2.5L TJ? Pics and part numbers will be extremely appreciated.
Thanks in advance.
Re: Power Steering Reservoir after Electric Fan Install
« Reply #1 on: August 10, 2011, 08:40:03 PM »
I think people were either fabbing up something similar to teh Flex-a-lite bracket (which I still have never seen) or replacing it with a universal reservoir.
« Reply #2 on: August 10, 2011, 08:47:00 PM »
there were a couple of threads around for this exact topic, one of the guys used a pre-drilled angle bar from home depot for the reservoir mount.
on another note, your email will end up in all the spammer's lists since you're using it as your screen-name - might want to ask Jeffy to change it (not sure if possible, he can clarify).
tinkerab@gmail.com
« Reply #3 on: August 10, 2011, 09:52:33 PM »
I do have the flex-a-lite bracket to hold my coolant tank but I did not know they had a bracket for the power steering.  If a moderator could point me in the direction of how to change my username I would appreciate it, I could not find it in the profile pages.
Thanks and still hoping some pics will surface maybe of this home depot bracket I have heard a few people talking about.
« Reply #4 on: August 10, 2011, 11:31:28 PM »
check this thread post #3 by Jeffy http://4bangerjp.com/forums/index.php/topic,7430.0.html
couldn't find the other thread with the home depot comment. (EDIT: it's in the same thread, reply#8 and mentions Lowes, that's why my search failed)
« Last Edit: August 10, 2011, 11:39:18 PM by sharpxmen »
Offline mrcabinet
« Reply #5 on: August 12, 2011, 08:17:38 AM »
This is what I did - cut up the old cowl for the overflow mount and used the wedge for the ps reservoir.
I made the mistake of not putting a "keeper" on the ps reservoir so it bounced off and committed suicide on the ps pump pulley. Replacements are non-existent, so I ended up with a BMW one from the wrecking yard. Works great!
« Reply #6 on: August 12, 2011, 12:35:30 PM »
what fan is that?  looks like a great fit and has a rubber edging
Offline mrcabinet
« Reply #7 on: August 12, 2011, 06:48:26 PM »
That's the Flex-A-Lite 485. About a year ago a guy in Washington had some "factory reconditioned" ones on e-bay for $200 so I snagged one. I was going to go the Taurus fan route but this was just to easy to pass up at that price. I have no idea why it is blue - all the others I've seen are black.
Offline mrcabinet
« Reply #8 on: August 12, 2011, 06:57:40 PM »
I just looked and Cascade Sales has them on e-bay again for $199.99.
« Last Edit: August 12, 2011, 06:58:14 PM by mrcabinet »
tinkerab@gmail.com
« Reply #9 on: August 12, 2011, 09:02:45 PM »
Well yesterday I ordered the flex-a-lite bracket that supposedly has a spot to mount the power steering reservoir, however today I notice that it is the same part # as the one I ordered before with no PS reservoir holder.  It is supposed to be here tommorow so If its the same thing ill probably make a bracket like yours. that looks pretty good.
tinkerab@gmail.com
« Reply #10 on: August 13, 2011, 03:33:17 PM »
Well I got the bracket and to my surprise it was different, it did have a spot for the PS reservoir.  However the bracket is to small and there is no way to hold both the power steering and coolant tank at the same time.
« Reply #11 on: August 13, 2011, 03:37:01 PM »
Slice it and weld or bolt a piece of plate in between so it has the width you desire
« Last Edit: August 13, 2011, 03:37:40 PM by aw12345 »
« Reply #12 on: August 13, 2011, 04:10:01 PM »
Use it as a template and add on what you need?
« Reply #13 on: August 14, 2011, 01:06:34 PM »
imo: since you now have 2 brackets, use the old one for coolant res and the new one for p/s reservoir. you can use an angle plate or 2 angle brackets to mount the second one like mr.cabinet did.
tinkerab@gmail.com
« Reply #14 on: August 14, 2011, 03:33:24 PM »
Yeah thats most likely what im going to do.  Im going to take the new bracket to work tommorow and Cut it down
