Author Topic: What axles are these? *Beware large format*  (Read 10616 times)
« on: June 27, 2005, 05:16:51 PM »
I'm guessing they're Ford Axles from the wheels but you can change those easily.
StefanBidi
« Reply #1 on: June 27, 2005, 06:04:43 PM »
That's definately a Dana 44/Ford 9" combo.  Had to adjust the contrast and brightness on my monitor, and then I could see it as bright as day!  Can't really tell if the front is a HP or LP housing though, but seems to be HP.  From the thrid picture it looks like he shaved a little off the 9".  The front axle also has disc brakes on it, if that tells you anything.
« Reply #2 on: June 27, 2005, 10:19:10 PM »
I'm wondering what they're from also.  Looks like they're full width, too.  The front's a D44, didn't bother to play around with contract for the rear.  I'd really like to get a front D44 though.  Then I'll be able to regear to something low.
Sure looks nice with those wheels and axles.
trailblazer95
« Reply #3 on: June 28, 2005, 07:49:23 AM »
the rear looks HP also, in which case it uses the same ring gears as the 8.8, so you could only go to 4.88.  Personally that axle setup sounds almost bulletproof with the 2.5L.
« Reply #4 on: June 28, 2005, 09:57:21 PM »
Those are pretty wide axles considering the wheels have a lot of backspacing.
I'll be going with a FSJ D44 front and Isuzu D44 rear with 5.38, as 4.88 just isn't low enough for the 4banger with anything larger than a 32" or 33" tire.  Nice thing about those two axles are the same 6x5.5" lug pattern and 4wheel discs.
That's a sweet relatively simple YJ doing some hellacious crawlin.
