Author Topic: Exhaust spits after ever gear, what will fix this?  (Read 1664 times)
jwrape
« on: March 15, 2006, 02:23:19 PM »
Hey guys. Everytime I run the RPM's up above 3k rpms the exhaust spits as soon as I push the gas for the next gear. For instancve i will shift from 1st to 2nd and as I let off the clutch and give it gas again to accelerate in 2nd it makes a spit sound from the exhaust.
I am running rich but I don't know if that is what is making it do that.
I don't know what to do to get it to run leaner. I have replaced the O2 sensor and moved the AIS forward to the air intake tube to fool the computer and that helped a little but it still runs too rich.
« Reply #1 on: March 15, 2006, 03:18:41 PM »
Spits?  So you're backfiring through the exhaust?  I'd suspect that you are running rich and it's getting into the exhaust where it ignites.
jwrape
« Reply #2 on: March 15, 2006, 04:06:34 PM »
Quote from: "Jeffy"
Yea, it spits like a small back fire. Not really loud. Almost sounds like if you held your breathe for a few minutes and then let it out really fast. Kinda like a big PUFF of air.
What can i do to resolve it. It's almost embarrassing.
Jeep runs good otherwise except the running rich and the spitting.
I was thinking about advancing the distributor to see if that helps.
