Author Topic: What toots your horn!  (Read 3732 times)
Nicks92jeeper
« on: January 06, 2012, 12:38:24 AM »
So I am a pretty aggressive driver and when you cut out in front of me I honk. The horn in the jeep is kinda pathetic in my opinion so yesterday I installed a 120 decibel air powered Wolo trumpet big rig horn. It was an easy install and I have the horn set up for push button activation!!! Here is the horn http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Trumpet-Big-Rig-Wolo_10013744-P_N3074_A%7CGRP2021_____#fragment-4
This is what I wish I could afford!!!!!!  :yikes: http://www.pbmissions.com/p6-Maximus-Horns-Level-2-Kit-170dB.html?osCsid=bd4e57565a90075ae8749318da3f5fd2
What set up do you have in you Jeep?
Re: What toots your horn!
« Reply #1 on: January 06, 2012, 06:14:20 AM »
if you have on board air setup you could just get the horns instead http://www.maximushornsystems.com/accessories.aspx
« Reply #2 on: January 06, 2012, 06:51:31 AM »
Got a great horn that I was going to put on my Harley but it was to large.  135 DB.  But cannot find out whats wrong with the Horn Button too it all apoart and nothing.  Must be the wire in nthe column its self.   Do need to get that fixed cause I've dam need smacked the steering wheel trying to honk the horn at some idiots.
« Reply #3 on: January 06, 2012, 03:22:13 PM »
check out horn blasters!!
« Reply #4 on: January 06, 2012, 03:52:39 PM »
I hate my horn.  It only has one horn.  I think it's the high horn so there's no bass to it.  Higher end Jeeps has two horns.  I like the GM horns from most of their trucks and higher cars.
Hella males a nice set of horns that are electric, Supertones.
Air horns are cool and all BUT for those big ones, you have to charge your tank and keep it charged.  That means running the compressor when you start the vehicle up then keeping it charged.  Kind of a PITA if you're going to only be using it maybe once in a month.
Stebel sells a horn that many motorcycles like to use.  THey go under a few different names but they're all from china, I think.  It's a compact electric horn that's loud.
Just keep in mind, you can get ticketed for a crap your pants loud horn.
« Last Edit: January 06, 2012, 03:52:55 PM by Jeffy »
« Reply #5 on: January 06, 2012, 05:15:14 PM »
My horn doesn't even work...  Yet one more thing that needs fixin!
« Reply #6 on: January 06, 2012, 05:59:57 PM »
Must be the year 94 :slapfight:
« Reply #7 on: January 06, 2012, 07:24:39 PM »
I got these in my wife P5
there not really a jeep sounding horn they are very high pitch and ear piercing import sounding. I have scared people with them!!
I want on board air soon so air horn/train horn is the way I want to go.
http://youtu.be/CwNZeRpBems super tones hellas
« Last Edit: January 06, 2012, 07:27:15 PM by Torch_Ind »
« Reply #8 on: January 06, 2012, 08:18:33 PM »
Got my Horns at
http://www.aerostich.com/catalogsearch/result/?q=horns
  The Ear Cannon was the one that would not fit on my HD and once I can get my Horn Button Working again I will put on the Jeep.
  The Fiam Freeway Blaster is what finally fit the HD, I like how it sounds.  Like one of the cars from the 50's it makes you turn to see whats coming.
« Reply #9 on: January 06, 2012, 08:56:59 PM »
Got my Horns at
That's the Stebel that just about everyone uses.
  • 4BangerJP.comŪ Donator
« Reply #10 on: January 06, 2012, 10:01:28 PM »
Mine is the Hella Dual Tone kit with the two horns and I think it's about 11 years old at this point.
It's good for highway traffic where when you hit the horn, it's probably to ward off somebody who doesn't see you.   In the city, if you're reminding somebody that a traffic light is green, it's enough just to give the horn a little tap.
One thing to look out for with this dual tone kit and probably Hella's tri-tone kit, also:
-Electrical connections to the pump itself. Hella provided latchless blade-type connectors on mine.  If your air pump is mounted upside down and the connectors are crimped, the connection can get disturbed (probably due to gravity, driving on trails and rough roads).
This happens and no horn when you need it.  I had this horn installed, then I moved, so I ended up correcting this myself.
« Reply #11 on: January 06, 2012, 11:21:35 PM »
No horn as much as the 7" HIDs :fish:
Nicks92jeeper
« Reply #12 on: January 07, 2012, 01:34:27 AM »
That is why I went with a push button and I have a 92. I figure though when I take the steering column apart to fix the turn signal switch I might accidently fix it and have another horn!!!
