Author Topic: performance upgrades what to do  (Read 6874 times)
duzie
« on: February 06, 2012, 04:34:32 PM »
1989 2.5 tbi 5 speed all stock 93,000 miles in the couple of hundred dollar range whats the first thing you would do to your jeep to get a little more  from it jeep is running fine currently but want more pep
Duck Dodgers
Re: performance upgrades what to do
« Reply #1 on: February 06, 2012, 05:34:38 PM »
4.0l TB swap. Added a bit more power to mine. Not a lot but enough to notice.
« Reply #2 on: February 06, 2012, 06:39:07 PM »
Won't work on a '89.
« Reply #3 on: February 06, 2012, 07:05:41 PM »
electric fan swap would be first on my list...
if you have access to a machine shop or someone that does boring the tb to 50 mm realy helps bring the tbi 2.5l to life. but its a one off thing unlike the 4.0l tb swap that the mpfi guys can do.
« Last Edit: February 06, 2012, 07:06:54 PM by chardrc »
Nicks92jeeper
« Reply #4 on: February 07, 2012, 01:19:41 AM »
Not sure of the setup of the 89 but perhaps, if it has a carb then spacer, opening up the opening for intake manifold? Msd ignition coil or something along those lines. Better spark plugs and wire. Perhaps a performance distributor cap and rotor. New fuel filter helps. Different blower motor for the heater (pretty toasty mod)
The E fan will help free up a few ponies. If you can do synthetic oil, that helps things move a lot better.
If carberated, is it possible to swap in fuel injected intake manifold and throttle body and add in the electrical components???
« Reply #5 on: February 07, 2012, 08:05:24 AM »
Not sure of the setup of the 89 but perhaps, if it has a carb  [...]
'89 is a TBI.
there are more differences than just the intake manifold for MPFI conversion: Cyl head, cam, fuel pump, filter, inside/outside wiring harness, temp sender for ECU, distributor and cam position sensor in it and i think but not sure the pistons are also different.
duzie
« Reply #6 on: February 10, 2012, 04:21:26 PM »
thanks for the input , i am thinking maybe a catback exhaust to start and go from there so many things available like being a kid in a candy store
« Reply #7 on: February 10, 2012, 06:02:58 PM »
I agree.  While an electric fan won't give you any HP, it does free up some HP lost by the fan.
Basica like a hi-flow cat and a cat-back exhaust will also help.
Nicks92jeeper
« Reply #8 on: February 11, 2012, 02:25:18 AM »
Get 5 buddies, a tool set, a random 4.0 jeep somewhere in town and the cover of night and you have a new engine and transmission!!!
« Reply #9 on: February 11, 2012, 12:36:54 PM »
Let him take your 4.0.  :fish:
Nicks92jeeper
« Reply #10 on: February 12, 2012, 03:27:30 AM »
I have a 2.5  :blbl:
« Reply #11 on: February 12, 2012, 08:31:58 AM »
I have a 2.5  :blbl:
i think that was his point  :wall:
Nicks92jeeper
« Reply #12 on: February 12, 2012, 07:12:27 PM »
That went over my head!
« Reply #13 on: February 12, 2012, 07:52:51 PM »
i think his point was that you don't have a 4.0 and didn't go out to town with 5 buddies to get one
hope it's clear enough this time
« Reply #14 on: February 12, 2012, 09:26:19 PM »
Joking or not, I don't take kindly to the suggestion. We all work hard for our toys. If he should pilfer someone, offer up your stuff first is my point. AGUHR could use a skid plate. Khvnp1l0t could use a radio.
