Author Topic: Change Valve Seals  (Read 3122 times)
robertsiii
Change Valve Seals
« on: March 18, 2012, 07:16:34 PM »
I tried to change intake and exhaust valve seals on the 2.5 this weekend . tried air first and then rope in the cylinder . i couldnt get the valve to stay up sealed so i could remove the keepers .  any advice ?  i did get my harland sharp  1.7 lifters installed .  noticed all around increase in power range .
Re: Change Valve Seals
« Reply #1 on: March 18, 2012, 09:04:02 PM »
you need to "break" the keepers from the dish, i usually put a socket over the dish and give it a tap, but that's with the head off and another socket on the valve to keep it flat, with the head installed it's a bit risky this way.
If that's not your problem then use a slightly bent bar to hold the valve up against the piston thru the plug hole, careful not to damage the threads (that's why you shoud be against the piston - don't tap the dish in this case, i assume you have a valve spring compressor to push the dish down otherwise it's a nightmare (if you don't have get one, they're about $10 or $15 at an auto-parts store).
robertsiii
« Reply #2 on: March 18, 2012, 09:14:12 PM »
thanks sharpx  i think i need more than two hands when i try it again  :brick:
« Reply #3 on: March 18, 2012, 09:38:44 PM »
it might work just with the piston at tdc but never tried this on the Jeep so i don't know, heads with domed (hemi) pistons you can usually do it as the valve is closer to the piston (you get the idea)
robertsiii
« Reply #4 on: March 19, 2012, 11:32:14 AM »
I tried to change intake and exhaust valve seals on the 2.5 this weekend . tried air first and then rope in the cylinder . i couldnt get the valve to stay up sealed so i could remove the keepers .  any advice ?  i did get my harland sharp  1.7 -----ROLLER ROCKERS----- :clap: installed .  noticed all around increase in power range .
« Last Edit: March 19, 2012, 11:42:13 AM by robertsiii »
robertsiii
« Reply #5 on: March 22, 2012, 06:37:42 PM »
Borrowed the right valve spring compression tool from a mechanic friend  today  . should be a easy job now .   im changing out the seals ,pushrods and hydrualic lifters  . the lifters on the #2 cylinder seamed spongy and i had a tic .  ill take some pics of the harland sharp roller rockers before i button her up.  MORE TO FOLLOW!
robertsiii
« Reply #6 on: March 24, 2012, 07:46:44 PM »
Got THE valve stem seals swapped out today  didnt foul with hyd. lifters ,just gonna wait till we have to rebuild. roller rockers sure do run cool .dropped 10 degrees on my cruising temp. never had to worry about a speeding ticket till now! :driving:
« Reply #7 on: March 24, 2012, 08:15:58 PM »
Looks nice.  I've always thought about swapping some in.
