Author Topic: Airaid TBS or not?  (Read 3856 times)
mattbo505
Airaid TBS or not?
« on: March 29, 2012, 07:12:34 AM »
Hey guys i have a 97' TJ 2.5 I re-geared a few years ago to 4.88's and absolutely love it. Recently i upgraded to 33x12.50x15r and obviously lost a little but the look was worth it. Then i installed an electric fan an Airaid intake and had flowmaster welded on and dropped outside the passenger door pointed downward. I was looking into the Airaid Throttle body Spacer but didn't know how much of a difference it would make I read Jeffy's product review on it but was curious if anyone had any experience or suggestions as to it's overall performance. Right now i'm running about 2500-2700 rpm's at 65 mph pretty comfortable ride for now. Should i install the TBS or leave it where it's at?????
JohnnyO
Re: Airaid TBS or not?
« Reply #1 on: March 29, 2012, 08:17:22 AM »
I don't have one, can't say how well they work, but most cost $80 to over $100 which I think is a crapload of money for a hunk of machined aluminum.  Rugged Ridge has one for about $40 and if I was going to gamble on something that may or may not work, that's the one I'd try.
My .02.
« Reply #2 on: March 29, 2012, 11:46:55 AM »
Well, I like mine but it's been bored to 63mm.  I liked it before since no one else was making them.  I think I paid $60-something for it.  I'd never pay more then that.  You used to be able to find smooth spacers for $20.
« Reply #3 on: March 29, 2012, 12:21:28 PM »
I think every little bit helps.  I have smooth-bore 62mm spacers that match my throttle bodies.
mattbo505
« Reply #4 on: March 29, 2012, 12:27:49 PM »
Well i found one on feEbay for 82.95 free shipping. It doesn't say what mm it is so i'm assuming (which i probably shouldn't do) it is 62mm. Any suggestions?
« Reply #5 on: March 29, 2012, 12:30:24 PM »
Just get one from Bounty Hunter.
« Reply #6 on: March 29, 2012, 12:45:48 PM »
if it doesn't say it's stock diameter and not 62mm
do you have a 62mm t/b? (just wondering why you're looking for one that size, if you have the stock t/b or 4.0L t/b you don't need a 62mm one, using a larger spacer will also hurt rather than improve anything).
mattbo505
« Reply #7 on: March 29, 2012, 01:23:31 PM »
Honestly i have no clue i guess i'll throw the nuuuuuub card there i didn't know much about throttle body stuff. I was just researching more add ons to increase some throttle response???
SDWE61988
« Reply #8 on: April 02, 2012, 11:30:14 AM »
I bought the Airraid one a few years ago now.  Did it make a difference.  a little,  Would I do it again, I am not sure.  I noticed much more of a difference with the electric fan and header additions.  Every little bit helps on these rigs.  I know a lot of the Charger/LX guys hate them and say they are worthless.  I do not have one on my charger, but that is also a totaly different machine.
tablesaw
« Reply #9 on: April 18, 2012, 04:04:41 PM »
I have a '95 with 2.5, 4.0 TB, 19# injectors, and stock intake. I know, i need to bore the intake. Read somewhere the airaids are actually smaller diameter because of the threads in bore. I just bought a smooth 62mm spacer on e-bay for $33. Can't tell ANY difference. Feel like I should have put the money in the gas tank. Now I'm a newb, and I've seen strong opinions on spacers elsewhere, but I just don't see where they benefit a mpfi engine. My injectors squirt almost directly into the head. If it had a carb or tbi, I could see it. I've heard about turbulence but don't think it applies to my engine. Is there something I'm not getting?  ???
« Reply #10 on: April 18, 2012, 10:10:07 PM »
nope, that's about it, little difference if any, something that helps the lower end imo so maybe that's why you don't notice anything
mattbo505
« Reply #11 on: April 19, 2012, 06:24:11 AM »
Hey Bounty whats a good setup you suggest?
