Author Topic: ring and pinion  (Read 7202 times)
Re: ring and pinion
« Reply #15 on: April 10, 2012, 07:38:45 PM »
IIRC, it was a Bronco D44 so it should be a LP.
I thought the HP came off of the F250's. From what I understand the Bronco's did come with LP fronts. But I am no expert.
kbar
Re: ring and pinion
« Reply #16 on: April 10, 2012, 07:43:53 PM »
I will go look in a min I'm on the  :flush:, I am pretty sure it's a hp, I js texted the guy though and he said it is an hp.
kbar
Re: ring and pinion
« Reply #17 on: April 16, 2012, 07:12:50 PM »
I am for sure it is a HP44 also found me a 5:38 for my ford 9
It is made by Motive
Re: ring and pinion
« Reply #18 on: April 16, 2012, 07:26:59 PM »
is it just me or that looks like a spun bearing?
kbar
Re: ring and pinion
« Reply #19 on: April 16, 2012, 07:37:26 PM »
The guy I bought from said he only used it one race I think it was a stock car race. I can always return it, so we will see.
Re: ring and pinion
« Reply #20 on: April 16, 2012, 09:54:05 PM »
You had a HP44 cut down?  F250's had HP44's but they were about 6" too wide.  I thought you were running Early Bronco axles for some reason.
Re: ring and pinion
« Reply #21 on: April 17, 2012, 10:55:56 AM »
A quick search showed that 5.38 is available for the 9" but the only ones I found were called "lightweight".
Are these different from (not as strong as) the normal R & Ps?
Re: ring and pinion
« Reply #22 on: April 17, 2012, 11:40:43 AM »
Seeing as most race cars in the US use the Ford 9", you'll find a lot of lightweights.  They're thinner gears.  You can see they mill out a bunch of metal from the backside of the ring gear.
Re: ring and pinion
« Reply #23 on: April 17, 2012, 12:18:01 PM »
i don't think that's going to affect the strength though, they usually brake teeth, never seen a cracked ring
kbar
Re: ring and pinion
« Reply #24 on: April 17, 2012, 05:50:22 PM »
I finally went and got a pic lol it's a 1978 Bronco axle
Yeah it was the ONLY sale I could find on ebay for a Ford 9 5:38.
« Last Edit: April 17, 2012, 05:57:01 PM by kbar »
kbar
Re: ring and pinion
« Reply #25 on: April 17, 2012, 06:04:38 PM »
The only $hitty thing I just found it that those radius arm wedges are casted into the tubes, so I will either have to leave them or retube them.  :brick:
Re: ring and pinion
« Reply #26 on: April 17, 2012, 06:15:15 PM »
Those bronco axels should be low pinion. The one we have in our garage is. And removing the tubes proved to be a real pita (we gave up on trying to drill out the plug welds as we were geting nowhere with every type of bit we could find)
Re: ring and pinion
« Reply #27 on: April 17, 2012, 11:21:35 PM »
Ah OK, that's a full-size bronco which will be HP.
Looks like your instrument panel is pretty rusted, too.
