Author Topic: whenever it rains my breaks don't work!  (Read 1940 times)
fobanger00
« on: April 23, 2012, 09:45:09 AM »
anytime it rains my breaks are not there occassionally they will kick in and it stops abrutly and sounds terrible.  is there a reason for this? brake fluid is fine and i had my front breaks checked they said they were fine also.
Re: whenever it rains my breaks don't work!
« Reply #1 on: April 23, 2012, 05:39:51 PM »
Not working as in pedal hits the floor and you're not stopping at all?  Or you're pushing the pedal and it's slowing a little but only grabs when at a low speed?
  • 4BangerJP.comŪ Donator
« Reply #2 on: April 23, 2012, 06:42:22 PM »
You've got some big tires.  If it was me, I'd get some better pads, front rotors, steel lines, dot4 synth brake fluid.  I like the  EBC rotors/yellow stuff pads on mine
You have a dual diaphram booster setup on your TJ, right (thought I heard all TJs had that)?  If mine was a YJ on 35s, I'd consider pulling one of those dual diaphram boosters from a '95 YJ or just order it new and swap that in there too.
How's your tire pressure, also?
fobanger00
« Reply #3 on: April 23, 2012, 08:30:31 PM »
tires are at the normal pressure maybe alittle more, and the are there but when it rains it feels like when i stop it leans in the front and squeals like there arnt pads even though there are, and they work mainly at really slow speeds even that isnt enough sometimes.
« Reply #4 on: April 23, 2012, 08:43:11 PM »
change the pads
bendix semi-metallic brake pads (MKD477 if i remember correctly, i bought them from amazon for $32 or so), i got some really cheapo ones for the rear and they make noise, fronts are great, i'll swap the rears to something like these too soon.h
« Reply #5 on: April 23, 2012, 11:14:11 PM »
Have you looked at the pads to see if there's anything left? Steel rivits against a steel disc don't make for good brakes.  Chews up the disc too.  BTDT.
