Author Topic: Sea Foam  (Read 4530 times)
Sea Foam
« on: May 13, 2012, 11:16:04 AM »
Has anyone ran Sea Foam in there gas tank? My Jeep sits for months and months and I was wondering if a fuel additive should be used. Sea Foam says it stabilizes fuel for a long time.
Any draw backs to using these types of products?
Re: Sea Foam
« Reply #1 on: May 13, 2012, 11:32:06 AM »
Pro/Con: The big white smoke cloud.
Re: Sea Foam
« Reply #2 on: May 13, 2012, 11:44:26 AM »
Why not add stabilant to the tank? It's specifically made to keep gasoline from detoriating.
Re: Sea Foam
« Reply #3 on: May 13, 2012, 11:52:40 AM »
you can always empty the tank as much as possible, you'd still be left with 1/2 a gallon or maybe more, just add another 2 gallons when you're ready to drive around. Unless it sits for a year or more you're fine. Mine sat for 2 years but i kept taking fuel out via the pump at the rail and adding fresh and had no issues (i replaced the fuel filter prior to restart).
Re: Sea Foam
« Reply #4 on: May 13, 2012, 05:15:01 PM »
i like to use seafoam in the tank about ounce a year. with throttel body injection it does a good job of cleaning the tb and manifold (although it wont help with mpfi but it does clean otehr components and i feel do good)
Re: Sea Foam
« Reply #5 on: May 13, 2012, 06:27:43 PM »
I thought it only did that when you add it to the TB.?
I might just do that next time.
Sometimes it sits for about 5-6 months. I start it every couple months and run it a bit.
I normally don't let it sit with a full tank. Normally it's less than 1/4. Is it better to store with a full tank or empty?
Re: Sea Foam
« Reply #6 on: May 13, 2012, 06:30:00 PM »
empty and add fresh gas before you start it, best if you run the pump for a minute or so to flush the rails.
Re: Sea Foam
« Reply #7 on: May 13, 2012, 06:48:05 PM »
with a metal tank its better to have it full so condensation on the inside doesn't rust the tank. for plastic tank idk but would think you would want to keep it low
Offline Danny in Galveston
Re: Sea Foam
« Reply #8 on: May 18, 2012, 10:06:47 PM »
With today's ethanol "enriched" gas, you definitely need to add a stabilizer such as Seafoam for extended storage to help minimize the gas separating and breaking down.  Also, the fuller you keep the tank, the better off you will be.  Ethanol will absorb moisture from the air and you will have water in your tank.  With a full tank you have less air and therefore less moisture to be absorbed.  I religiously use Seafoam in my bike because it sits a lot more than my Jeep.  About twice a year I run some through the Jeep to keep things clean.
Re: Sea Foam
« Reply #9 on: May 18, 2012, 10:53:04 PM »
How bad does it smoke when you run sea foam through the gas tank?
Re: Sea Foam
« Reply #10 on: May 20, 2012, 06:48:04 AM »
The jeeps in my family don't smoke when seafoam is run through the exhaust. Atleast not noticably.
Re: Sea Foam
« Reply #11 on: May 20, 2012, 09:35:11 AM »
Will agree does not make mine smoke either.
Re: Sea Foam
« Reply #12 on: May 20, 2012, 12:12:28 PM »
I ment when run through gas tank...
