Author Topic: need a rebuilt tranny 1995 2.5L - where most reputable place to get  (Read 7140 times)
Offline bestos
need a rebuilt tranny 1995 2.5L - where most reputable place to get.
can anyone help?  I am not planning on doing my own rebuild or paying someone to rebuild, it seem easier to buy and have delivered on internet.  anyone have recommendations.
Re: need a rebuilt tranny 1995 2.5L - where most reputable place to get
« Reply #1 on: August 13, 2012, 11:21:43 AM »
my recommendation is to ditch the AX5 and get a junkyard NV3550, it's just not worth rebuilding - too weak for offroading and bigger tires.
Offline bestos
« Reply #2 on: August 13, 2012, 11:52:19 AM »
i am not discounting your opinion, but the cost for those is MUCH higher. MUCH in my area.  non standard clutch, new bellhousing, new input gear on xfer case.  I do not have the funds for that operation. and the transmission itself is 3x the money.
i am taking this jeep back to 31s. it is a road/DD - it does not go offroading other than getting thru snow drifts in winter.
« Reply #3 on: August 13, 2012, 01:37:49 PM »
I'd get a Salvage AX-5 then.
« Reply #4 on: August 13, 2012, 01:40:52 PM »
a reman is somewhere between $600 to $1000 depending on what was replaced in it and probably what you want to be new and fresh inside the transmission (in my opinion you should at least have all bearings and synchros replaced (and of course the 2 seals). Having a shop do the reman for you would possibly cost more or about the same as buying an already reman transmission but the only thing is you don't know what's been replaced in it, there is a chance that most parts were inspected and only the synchros were replaced (and even then maybe not all).
the reason i mentioned the upgrade is that in the end it will probably cost you about the same and have an upgraded transmission - lots of places would let you swap your t-case with a proper input one if you buy the transmission from them, there is no shortage of NP231 with 23 input splines.
the clutch can be had new for $100 (Luk) but you can only use the disc out of it, a bit of waste of money but it's not that extreme. A reman Camaro clutch disc is somewhere around $50 probably, nothing else involved in the clutch replacement other than swapping the disc with the Camaro one. transmission mount can be reused from the AX5 but you need to elongate the mounting bolts.
fairly straight forward and popular swap
anyway, just my opinion, indeed the AX5 would be the easiest way to go since there's no custom work at all.
« Last Edit: August 13, 2012, 01:41:47 PM by sharpxmen »
Offline bestos
« Reply #5 on: August 13, 2012, 02:11:13 PM »
looking into it, gotta do some more checking.
the cost of shipping will basically equal out the nv3550 (which i found local for 1k) and the rebuilt ax5 850 + ship.
« Reply #6 on: August 13, 2012, 02:28:33 PM »
i would negotiate the NV3550, costs are somewhere between $500 and $800 depending on miles, i understand if they're scarce where you're at but it's worth a shot. couple of things i forgot to mention that you also need
 - an advance adapters pilot bearing (bushing)
 - if the short shifter lever in the shift tower has a bent in it (kind of an S curve) you'll have to take that lever out and rotate it 180 deg (otherwise it's too far back), pretty easy to do with a snap ring pliers if i remember correctly - might not be needed if you don't have a center console but it fits really well that way.
« Reply #7 on: August 13, 2012, 02:53:42 PM »
here's the Advance Adapters pilot bushing needed
P/N 716167
http://www.advanceadapters.com/products/pilot-bushing-750-id-x-1090-od-x-950-thick/
the rest of the parts
Dodge Dakota 2.5L/4cyl 96-98 Transmission Bellhousing
Chevy Camaro 84 4cyl/4sp Clutch Disc
NP231 23 spline input shaft (or the t-case with the proper input shaft)
« Reply #8 on: August 13, 2012, 03:04:20 PM »
I would stay away from a rebuilt AX-5.  Unless they really know what they're doing, most rebuilds don't last very long and with shipping, you wouldn't want to be shipping a trans back and forth.
« Last Edit: August 13, 2012, 03:04:31 PM by Jeffy »
  • Servicing Squirrels Since 1995Ū
« Reply #9 on: August 13, 2012, 06:04:36 PM »
http://collinsbros.stores.yahoo.net/rebtran.html
At the very bottom of this page they have brand new (NOS) AX5's. But pricey $1700.00  They also have re-man for about $1K
Offline bestos
« Reply #10 on: August 13, 2012, 08:27:09 PM »
so there is no issues with the shaft length from the crank to transmission?  that works out perfectly?
« Reply #11 on: August 13, 2012, 08:39:25 PM »
[if the question was for me]
the pilot bushing sticks out about 1/2'' more compared to the stock pilot bearing/bushing just about as much as the bellhousing is deeper, so no, no issues with the input shaft.
Offline Eucalypta
    • Eucalypta Oud-Hollands Snoepgoed
« Reply #12 on: August 14, 2012, 03:14:35 AM »
Not trying to hijack this topic (but....)
I rebuilt my AX5 about a year ago. An experienced mechanic was present and did most of the work (to be honest).
We drive the car mostly in trials and offroad and this spring the rebuilt AX5 locked driving on the highway and probably got damaged badly. Not sure what happened, not yet opened the case to inspect it.
Instead I just put in a used AX5 (from a XJ). Now this AX5 is also making some noise so I guess this one needs new bearings.
Instead of rebuilding the 2 AX5's, I am VERY interested in swapping the AX5 for the NV3550.
I have the following question:
The parts mentioned below with the exception of the NV3550 are hard to find for me in The Netherlands.
Is any of you willing to buy and ship them to me?
(esp the bellhousing and clutch disc)
Ofcourse I am willing to compensate you for time and trouble.
Please respond by sending me a message.
To Boldly go where no one has gone before - James T Kirk
1994 YJ 2.5L - 1996 ZJ 5.2 V8
Offline bestos
« Reply #13 on: August 14, 2012, 05:45:10 AM »
so far, my biggest hangup is finding a bellhousing.  car-part.com does not list one available, which is very weird.
« Reply #14 on: August 14, 2012, 08:45:07 AM »
Darn, when i got mine there were plenty - found one only with no price listed.
1998 Transmission Bellhousing Only
Dodge Dakota 2DR,TRUCK,4X2,2.5,5SP   B13274
$Call Givens Auto Parts #3 USA-GA(Lawrenceville)
Request_Quote 770-963-0067 / 877-421-9558
EDIT: there are 2 more but i have no idea if they're the same since the years are different, the 2001 doesnt list the motor but comes out in the search, 2000 lists 2.5/5sp which is what is needed but I didn't even know this one was available in 2000 and not sure if it fits or not (maybe someone knows)
2001 Transmission Bellhousing Only
Dodge Dakota W.ARM A ST4674 $75 Orient Auto Parts & Recycling USA-OR(Gresham) E-mail 503-663-1909 / 877-663-1909
2000 Transmission Bellhousing Only
Dodge Dakota NICE DAKOTA 2.5 5/SPD BELLHOUSING A Z00755 $69.95 Marshalls Auto Parts, Inc. USA-OH(Circleville) Request_Quote 1-800-333-2104
« Last Edit: August 14, 2012, 08:51:53 AM by sharpxmen »
