Author Topic: Allignment - Caster +4 degrees on both front wheels  (Read 4048 times)
  • 4BangerJP.comŪ Donator
« on: October 13, 2012, 02:39:04 PM »
How do you tend to correct Caster angle on a YJ?  Local tire shop I used referred me to a local body shop for the Caster work...
Figuring it's result of trail driving and might just live with it.  Doesn't drive bad as is.
http://i250.photobucket.com/albums/gg271/leeiaccoca/Allignment1_zps26547d3a.png
http://i250.photobucket.com/albums/gg271/leeiaccoca/Allignment2_zpse92f6f1e.png
Re: Allignment - Caster +4 degrees on both front wheels
« Reply #1 on: October 13, 2012, 03:24:21 PM »
angle shims under the spring perches.
« Reply #2 on: October 13, 2012, 06:11:47 PM »
Different than stock shackles will change the angle.  If it drives well, I wouldn't worry about it.  My YJ is a bit off too but drives well enough.
« Reply #3 on: October 13, 2012, 06:48:51 PM »
Does it wander on the road? If it tracks well don't worry about it.
Caster is basically there to make sure that the steering returns to straight and help keep it from wandering all over the road
« Reply #4 on: October 13, 2012, 07:28:03 PM »
Ok, the shackles.  Makes sense.
Took a multiple choice test:
Question:  How did wheels get off by close to the same caster angle on both wheels?
A) Both front wheels hit an obstacle at the same time/force to cause both wheels to suffer nearly identical caster misalignment
B) Guy at tire shop good at hacking alignment computer in an attempt to generate business for brother's body shop
C) CARB sends goons to adjust caster angle 4 degrees on both wheels of any CA vehicle that has failed emissions.  Any alignment technician seeing this 4 degree caster result number for both wheels knows to remind customer to get his automobile's emission problem corrected, immediately.  If customer questions technician's awareness of automobiles emissions test failure --given that customer is at an alignment shop-- technician should act surprised, say he thought he heard customer mention it earlier...
D) All of the above, A-C
E) None of the above, A-C
I went with D.  Turns out E.  D#$$%t!
« Last Edit: October 13, 2012, 07:28:59 PM by chrisfranklin »
« Reply #5 on: October 13, 2012, 08:26:50 PM »
It would take severe trail abuse to change caster, and it likely wouldn't be the same on both sides.
Do you have longer shackles installed? +5* is acceptable so you're close.
« Reply #6 on: October 13, 2012, 08:38:27 PM »
Yes, some front/rear that yield about 1" of lift.  That appears to be the likely culprit.
« Reply #7 on: October 14, 2012, 12:31:40 PM »
Caster being low does not cause tire wear, so if it drives good move on to something else.
« Last Edit: October 14, 2012, 12:33:07 PM by aw12345 »
chuck172
« Reply #8 on: October 19, 2012, 04:55:32 PM »
So with a stock yj, is there any reason why caster would be out of whack.?
« Reply #9 on: October 19, 2012, 05:04:18 PM »
On a stock YJ, the leafs can flatten out which cause the caster to change a little.
