Author Topic: heater issues  (Read 3226 times)
95yjman
heater issues
« on: October 16, 2012, 11:49:44 PM »
The heater in my 97 TJ only works on the high setting, I replaced the resistor and it didn't change anything.  Do you think its the switch in the dash?  I checked the fuse and its good.  The fuse for this is located behind the glove box right?  Just to make sure i wasn't checking a fuse for something else.
Re: heater issues
« Reply #1 on: October 17, 2012, 01:25:59 PM »
If it's not the resister then it's probably the switch.
95yjman
Re: heater issues
« Reply #2 on: October 21, 2012, 07:36:21 PM »
Cool thanks, anybody know if it is gonna be hard to seperate the steering shaft where it bolts to mount which is bolted to the frame?  I have install my bracket that brings the steering shaft up an inch..
Re: heater issues
« Reply #3 on: October 21, 2012, 07:44:30 PM »
i have a 1'' b/l and didnt install any bracket, no issues so far
95yjman
Re: heater issues
« Reply #4 on: October 21, 2012, 08:03:35 PM »
yeah I was kinda on the fence about installing it. It had a 2 inch body lift on it when I bought it and didn't have one on.  I have since lowered it to a 1 inch body lift.  I didn't know if i was doing harm by not putting the new bracket on.  My steering wheel isn't centered but it never has been since I bought it.  I was figuring it was due to the steering shaft angle. May need a alinement too..
Re: heater issues
« Reply #5 on: October 21, 2012, 10:41:12 PM »
when you lift it you need to adjust the drag-link to get it back in the center, probably what happened. drop pitman arm corrects the issue slightly but you still need adjustment. Unrelated to the body lift but related to the suspension lift (just to clarify what i meant by "when you lift it).
95yjman
Re: heater issues
« Reply #6 on: October 22, 2012, 01:10:36 AM »
Suspension is stock, always has been. Only kind of lift this Jeep has had is body lifts..
Re: heater issues
« Reply #7 on: October 22, 2012, 01:25:10 AM »
that shouldn't affect your steering wheel centering, you need to adjust it or maybe an alignment.
