Author Topic: How do they mount?  (Read 2313 times)
95yjman
How do they mount?
« on: October 25, 2012, 09:50:35 PM »
How do the little flare extensions mount on a tj? Some of the holes to mount them are fully closed to where you run a bolt or anything.
Re: How do they mount?
« Reply #1 on: October 25, 2012, 10:01:28 PM »
you mean the splash guards up front? bolts go thru them and into the tub, at least that's how those were on my YJ.
95yjman
« Reply #2 on: October 25, 2012, 10:08:37 PM »
They mount different then the yj. The yj was that simple just a hole that you could get to on both sides. With the tj they have enclosed it so that if you take them off there isn't a bolt hole on the inside of the tub. I will have to take some pictures so you know what I mean.
95yjman
« Reply #3 on: October 25, 2012, 10:16:41 PM »
Ok here is the outside of the jeep with the mounting holes
and here is the inside
I'm guessing there was mounting hardware inside the holes that is long gone since the old ones where taken off.  How should I go about mounting my new ones?
« Reply #4 on: October 25, 2012, 11:59:04 PM »
Nutserts, available at the dealership.
« Reply #5 on: October 25, 2012, 11:59:46 PM »
You don't need to get to the backside.  There should be two, although one looks to be missing, nutserts in those two small holes.
95yjman
« Reply #6 on: October 26, 2012, 01:06:54 AM »
Ah I see, they are all mising but one...Thanks guys for the help!  ;)
